Installing luggage rack
Old May 1, 2011 | 08:50 AM
BARRY L-48's Avatar
BARRY L-48
Default Installing luggage rack
I am getting ready to install a luggage rack on my 77 coupe,would appreciate any tips on installation outside of don't drill into the gas tank,this car did not come with one on so there are no existing holes,it is an 8 hole rack. Thanks.
Old May 1, 2011 | 09:14 AM
jeffp1167's Avatar
jeffp1167
you won't go through the tank. (unless the 82's tank is in a different location then a 77 hahaha) If you need reference points of where the holes were originally let me know and I will check back of my 82 which has a 75 vert clip on it.
Old May 1, 2011 | 09:54 AM
jeffp1167's Avatar
jeffp1167
think mine was a 8 hole rack, can't remember or maybe the fuel door relocation cover the other 2 holes. but this should give you the general idea of where the holes were originally. The clip was from a 75 if I remember correctly mine could have been a 6 hole rack as well. will look at the car later and see if 2 holes were just not visible in the picture.
Old May 1, 2011 | 10:17 AM
7T1vette's Avatar
7T1vette
Just make sure that the gas lid can open without hitting any cross-bars. There's only a small bit of clearance...even with one that is properly positioned.
Old May 1, 2011 | 10:37 AM
'75's Avatar
'75
Here is mine for reference
Old May 1, 2011 | 10:48 AM
javaman's Avatar
javaman
2025 C6 of the Year Finalist - Modified
2021 C6 of the Year Finalist - Modified
Thought this might be a good time to raise this again.....my 69 has a rack and when I re-paint (maybe next year, wife permitting LOL) I definitely plan to remove the rack. Personally don't like the look. What do you guys and gals think about racks?
Old May 1, 2011 | 10:51 AM
U17's Avatar
U17
Would not have a C3 without one....
Old May 1, 2011 | 10:53 AM
'75's Avatar
'75
I personally like it, it breaks up the long rear deck.
Old May 1, 2011 | 11:50 AM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
I have one, honestly if I was to repaint I would take it off. I think it looks much better without it.
Old May 1, 2011 | 11:52 AM
BARRY L-48's Avatar
BARRY L-48
A big thanks for all your input,this will certainly help!
Old May 1, 2011 | 01:14 PM
Domer's Avatar
Domer
Use the positioning that "'75" has shown on his yellow vette. Remember to make sure that the clearance for the gas lid is there because it is no more than 1/4 inch total!
Measure, then do it again to make sure. If you're afraid to go too far, use a piece of tape on the drill bit to measure the depth of no more than 1"".
Good luck, it is really very easy about 2 out of 10 for difficulty.
Domer
Old Jul 3, 2011 | 09:27 AM
LancePearson's Avatar
LancePearson
Something else to learn...I did my stainless installation easily and put the 1/2" wellnuts supplied in, the rubber washers around them then the stainless washers over them with the small indentations in the center down. Placed the rack on towels then carefully put the stainless spacers in, the bolts in one by one then tightened. Great installation but later had a change of heart since there were no assembly instructions with mine and undid it, turned the stainless washer indentation up instead of down and retightened.
Big mistake. I ended up taking it apart yet again and putting the stainless washer dimple down. Why? that dimple holds the top of the wellnut still while your bolt goes into the nut at the bottom. Without it the hold and 1/2" diameter of the Wellnut od aren't tight enough and it tends to just spin and won't snug up at all well.
Retightened and now all is well. Small thing but very purposeful it seems to me.
Lance
Old Jul 3, 2011 | 11:05 AM
Binnie77's Avatar
Binnie77
Here is a copy of the original GM installation instructions for your rack. Note the back set of rack holes are drilled 4.14" in from bumper seam.
Old Jul 3, 2011 | 11:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Center your rack on the rear deck. Mark the mounting hole locations. You can use the posted pics for reference, but your rack may be different from others.
With hole locations marked, ensure you can open the fuel door.
My advice is to use a hole saw for cutting the holes. It's easier to saw fiberglass than to drill through it.
FWIW: the 77 AIM will show the hole cuttng and mounting for the optional 77 V54 rack. Might not hurt to look at the diagrams.
Old Jul 3, 2011 | 11:18 AM
LancePearson
thanks for the sheet...interesting that it shows screws rather than bolts. Was this before Wellnuts were around? I kind of like the Wellnuts. I have it installed correctly now and have had the car up to just under three digits with luggage on it when I first put it on. Works fine.
Lance
Old Jul 3, 2011 | 11:24 AM
Binnie77's Avatar
Binnie77
Lance
GM called them 'sealing nuts' rather than 'well nuts' on the instruction sheet. I believe that GM called any bolt without a hex head a screw.
Old Jul 3, 2011 | 12:09 PM
arkus's Avatar
arkus
I think luggage racks ruin the lines of the car . I hate them !
To Installing luggage rack
Old Jul 3, 2011 | 12:13 PM
Binnie77's Avatar
Binnie77
I believe Barry was asking for advice on the rack installation.
Old Jul 3, 2011 | 12:22 PM
LancePearson
Default luggage racks
Some of us think exactly the opposite of your views for some model years of our C-3's and think it actually adds to their looks.
It's a subjective thing. I personally love the C3 shapes but think the modern vette shapes are not at all attractive.
Functional, yes, very. Attractive as art, sculpture, appearance, not in the slightest.
Lots of C3's owned by lots of people just for the lines. Modern cars sure have better engineering so it must be the shape and appearance of them.
Old Jul 3, 2011 | 12:41 PM
arkus's Avatar
arkus
thats why i own both
