Stripped Threads on A/C compressor
Old May 1, 2011 | 03:00 PM
beige79's Avatar
beige79
Default Stripped Threads on A/C compressor
Well, this has been a fun weekend. I just picked my car up from the shop on Friday, after having the A/C compressor replaced. I started the car Saturday morning and the (3 month old) alternator belt broke and flipped the A/C belt upside down on the pulleys. Not sure why that happened, unless the shop did not install the belt properly.
So, I went to get a new belt and replaced it. When finishing up, all I had to do was tighten up the A/C compressor and the bolt just kept turning. I didn't put any undue pressure on the wrench, but the bolt would not tighten. I must say the the bolt was tight when I loosened it. When I backed it out, some metal threads came out with the bolt.
So, am I screwed here or is there a way to fix this? I really hate to bring it back to the shop. Hoping I didn't ruin a brand new compressor.
Old May 1, 2011 | 03:23 PM
Paul Workman's Avatar
Paul Workman
Commonly repaired with a Heli-coil which you can pick up at just about any auto parts place worth it's salt.
It involves drilling out what's left of the old threads, then tapping threads for the Heli-coil to screw into, and voila! good (or even better) than new! (Heli-coils are sometimes used in racing engines as the coils offer more surface area to the block and provide a smooth uniform thread surface to the threads of the head bolts - promoting uniform pre-load.) I just recently had to do a couple on my wife's L46 when I was installing a new cam in it. A couple rusted bolts broke off (rusted off?).
Its easy. I believe AutoZone has a kit which included the proper size drill bit along with the tap that comes with the kit.
P.
Old May 1, 2011 | 03:39 PM
beige79's Avatar
beige79
Thanks. I was hoping something like that could be done. I appreciate your response. Now I don't feel quite as bad.
Old May 1, 2011 | 03:58 PM
corvetteload's Avatar
corvetteload
Most likely a piece bolts to the compressor to provide the mounting points, bolt does not go directly into the comp. Replace the piece bolted to the comp, bracket or brace and forget about heli-coils
http://www.docrebuild.com/dr-r-web/AC-COMPRESSOR.HTML
Old May 1, 2011 | 04:36 PM
beige79's Avatar
beige79
I don't know. Looks like it just screws into the back of the housing to me. It is a reman AC/Delco.
This is another mounting point to the right of the first hole. This one won't work with the bracket that I have. Looks like it just screws into the housing to me.
This is the mounting hole that is stripped.
Old May 1, 2011 | 08:55 PM
08vycpe's Avatar
08vycpe
I put a new compressor (not reman) on my '79 last summer. I found that the newly manufactured compressor was made with metric threads and fasteners. I almost stripped out the hole with the original fasteners when I put it on. The bolt just didn't seem to start correctly after a turn or so. I realized the SAE to metric issue in time. The adjusting slot on the original mounting bracket was also too narrow for the metric fastener. I had to grind the slot wider to accomodate the metric diameter of the bolt.
Old May 1, 2011 | 09:17 PM
C3bdj1's Avatar
C3bdj1
St. Jude Donor '10
P.
That's the way to go...Please don't ask how I know.
Bobby
Old May 1, 2011 | 09:19 PM
beige79's Avatar
beige79
I think you may be right. I took the bolt and threaded it into the other mounting hole and ran it in about an inch. The bolt is still loose and you can wiggle it around. Looking like it might not have been all my fault after all.
I was wondering because the bolt went in easy and there was no resistance that you might expect if cross threading. I think I will have a little talk with the shop tomorrow.
Old May 1, 2011 | 09:21 PM
speedreed8's Avatar
speedreed8
that threaded hole for the adjustment bolt is METRIC>
Old May 1, 2011 | 09:45 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
A friend's 78 had the 7/16 fine thread bolt replaced with a long 3/8" thru bolt with a washer and nut on the other end.
I replaced that with the proper bolt. At the time I originally thought it had been stripped out.
But the longer bolt with the nut had worked fine, just wasn't 'correct'.
To Stripped Threads on A/C compressor
