Problem with headlight operation
Old May 2, 2011 | 05:12 AM
Dan Trotman's Avatar
Dan Trotman
Default Problem with headlight operation
I started troubleshooting my headlights yesterday (they won't close) and found a problem with the headlight relay valve assemblies. Both are leaking, one worse than the other. Are these available new from GM or vendors or can they be rebuilt? Thank you in advance for any help/advise.
Old May 2, 2011 | 05:37 AM
dgood's Avatar
dgood
Dan, you can get them from almost all the vendors here, willcox, ZIP, corvette america, RIKS. Not sure on the rebuild of the valves though. Someone will chime in though. HDL-111 for 127 dollars at ZIP.
Old May 2, 2011 | 12:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My 1983 parts and illustration catalogue lists #5638427 for the vacuum relays. You can try your Chevrolet parts department, but I would not be surprised to learn they are no longer available from GM.
Old May 2, 2011 | 02:13 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
We have the GM units in stock. Our part number is HDL-111
Old May 4, 2011 | 11:28 PM
Dan Trotman
Default Headlight problem- parts
Thanks mucho for all the help. FYI- these relay valves are still available thru GM and the part number given above is a good part number.
To Problem with headlight operation
