Removing Headlight switch?
Old May 6, 2011 | 02:24 PM
Clams Canino's Avatar
Clams Canino
Default Removing Headlight switch?
I have the little tool - but that's not the problem.
I can't get the **** shaft to pull out - even pressing the little button.
Is there a trick? Do I have to turn it one way or the other?
Thanks!
-W (back to work on it - again)
Old May 6, 2011 | 02:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I believe pressing the button does the trick and admit the button on the switch in my 68 is a finicky thing. I have to get it just right before it releases the rod.
Old May 6, 2011 | 02:32 PM
Clams Canino
Thanks!
While your here.. as I recall it was Rick that has the 68 parts car - right?
-W
Old May 6, 2011 | 03:09 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Use varying degrees of pressure on the button while simultaneously pulling and pushing (not enough to push it back in, just a slight nudge) on the rod. Eventually the stars in heaven will align properly and it will release.
Old May 6, 2011 | 03:44 PM
Clams Canino
Heh... I finally opened up the old switch. New one is in.
-W
Old May 6, 2011 | 10:19 PM
shrekviper's Avatar
shrekviper
I had issues with mine too. The correct method is Pull **** out to stop, push release button, push **** in to stop, pull **** completely out... There's nothing finicky about it (unless you've got Easy Mike's switch). You'd think it'd be published somewhere
Old May 6, 2011 | 10:39 PM
Clams Canino
Originally Posted by shrekviper
I had issues with mine too. The correct method is push button and hold, pull shaft out, push in, pull out. There's nothing finicky about it. You'd think it'd be published somewhere
It is now.
Let's all remember this for the "next guy" ")
-W
Old May 7, 2011 | 09:10 AM
Easy Mike's Avatar
Easy Mike
...There's nothing finicky about it....
You don't have my switch.
I can push it once and it will refuse to release the rod. Push it a second time holding my tongue correctly, and rod releases like it should.
Old May 7, 2011 | 01:34 PM
shrekviper's Avatar
shrekviper
I stand corrected...I broke my first switch trying to figure this out.
I updated my post, the correct method (just tried it again)...
Old May 7, 2011 | 09:37 PM
Birdman's Avatar
Birdman
What's the "little tool" that you mentioned?
I'll be pulling my headlight switch out soon, and thought you just had to press that little button.
Old May 7, 2011 | 10:46 PM
Clams Canino
There's a little "spanner socket" tool to undo the nut in the front of the dash that holds the switch on. A must have.
-W
Old May 7, 2011 | 11:06 PM
Birdman's Avatar
Birdman
-W
We'll see about that!
-Bubba
Old May 8, 2011 | 01:00 AM
shrekviper's Avatar
shrekviper
-W
It's a VERY VERY VERY nice to have. Not impossible w/o it, but you'll be happy to have it. I used a VERY wide screwdriver. The socket is the right way.
Old May 9, 2011 | 10:39 AM
Easy Mike's Avatar
Easy Mike
...I stand corrected...
Personally, I am convinced holding your tongue in the right place is the trick.
To Removing Headlight switch?
