1972 LT1 questions
Old May 12, 2011 | 07:53 PM
bsewell's Avatar
bsewell
Default 1972 LT1 questions
Hi all,
I am looking at a 1972 LT1 convertible. The vin includes the "L" and the owner reports the numbers to match through the drivetrain and reports correct numbers for everything including the heads and the carb. The car is about 800 miles away and I plan to make a personal inspection at the time of purchase.
The car has the 6500 rpm tach. It is a 4 speed. Most of the easy stuff checks out. What else can I look for to make sure I am getting a real LT1 car?
The biggest concern I have so far: the car is advertised as an AC car. Now I will confirm that the car has AC dials, it has the vents in the center and it looks vintage. But I don't believe the LT1 AC cars had the 6500 rpm tach. Is that correct? I suspect someone added the AC console unit but there is probably no duct work behind it.
Additionally the block suffix is CRT which was not marked for AC as far as I can tell.
Just for additional conversation/information, the car is gorgeous inside and out with great paint and interior and it is priced in the mid 20s.
I look forward to your thoughts, suggestions and especially to those of you eager to tell me what an idiot I am.
Old May 12, 2011 | 08:03 PM
Mike Ward's Avatar
Mike Ward
CRT is the correct code for LT1 with manual and A/C. Unless you're very experienced with stamp pads, hire somebody to inspect that part of the car for you. Make sure the AIR system intact, that's pricey to replace.
Mid 20s sounds quite reasonable for a convertible in excellent condition.
Old May 12, 2011 | 08:10 PM
Gordonm's Avatar
Gordonm
If it has AC it should not have a 6500 tach but a 5600 red line tach.
mid 20s for a true LT1 AC car in good condition is dirt cheap.
Old May 12, 2011 | 09:01 PM
Paul L's Avatar
Paul L
If you wish to be an idiot tell me where it is. A very rare car.
Old May 12, 2011 | 10:29 PM
GD70's Avatar
GD70
If it's legit for that price grab it and run before the owner changes his mind.
Good luck and post pics or have the current owner send you pics, of EVERY aspect of the car before you make a 1,600 round trip.
Good luck, Glenn
Old May 12, 2011 | 10:57 PM
bsewell's Avatar
bsewell
I think I'm going to try to hire an independent inspector to check it out before I go. Seems like a couple of hundred bucks well spent.
Anyone have a suggestion for an inspector in South Florida?
Old May 13, 2011 | 03:36 AM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Old May 13, 2011 | 04:20 AM
7T1vette's Avatar
7T1vette
Just curious.... Are you saying that the '72 LT-1 car without A/C came with a 6500 [tach] redline...but the same engine with A/C came with a 5600 redline? I thought the GM engineers finally relented on putting A/C in an LT-1 car because the '72 engine wouldn't really wind that high anyway.
Old May 13, 2011 | 06:15 AM
R1234's Avatar
R1234
Engine suffix should be CKY and the 72 LT-1 motor will wind just has high as a 71 and 70. The 5600 tach was installed to deter the owner from winding the motor too high to prevent from slinging the ac belt off.
Old May 13, 2011 | 08:31 AM
garage-ghost's Avatar
garage-ghost
The block suffix CRT is a rare find. It doesn't have anything to do with the car having air conditioning. It is thought to be for the LT-1 California A.I.R. cars. Most 72 LT-1s had the CKY suffix with or without air conditioning.
The only way to be sure if the car is supposed to have air conditioning is by the order copy or window sticker.
Old May 13, 2011 | 10:37 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Interesting information... I'll have to check that one out.
I know a gentleman who's brother purchased a '72 LT-1 with C-60 new in California... His brother sold it to him in 1976 and he's had it ever since. I've offered to buy the car a few times and have even driven it, but I don't remember what the engine broadcast code was. Next time I head back to my home town, I'll look him up and find out what it is.
As you mentioned, the C-60 LT-1s that I've seen have been coded CKY just lile the non-a/c LT-1s.
Regards,
Stan Falenski
Old May 13, 2011 | 10:40 AM
Rowdy Rat's Avatar
Rowdy Rat
LOL
I picked up an LT-1 with C-60 a while back that sold new from a dealership in Maryville, TN... You wouldn't be the one responsible for beating the **** out of this car, would you?
Regards,
Stan Falenski
Old May 13, 2011 | 12:41 PM
7T1vette's Avatar
7T1vette
Not me! (I'm pleased to say) I've had 4 Corvettes over the years and have taken very good care of each. I think the person you are referring to is "Bubba"!!!
Old May 13, 2011 | 04:18 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Originally Posted by bsewell
Hi all,
The L in the VIN confirms that its a real LT-1, if it came factory equipped with C60 (air conditioning) it would have a 5600 rpm redline on the tach, 6500 rpm was the redline for all the non a/c LT-1's. The last couple of LT-1 w/ac cars I have seen on ebay and here on this forum have sold for around 40k.
Mid 20's for a "gorgeous inside and out with great paint and interior" sound like a very good buy, but, like everyone here will tell you a personal inspection is warranted in this case. I suspect the a/c was added on at a later date, as someone mentioned above, the only true way to tell is if there is a copy of the build sheet.
Let us know how things turn out.
Regards
Roy
Old May 13, 2011 | 05:14 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Old May 13, 2011 | 05:19 PM
Alan 71's Avatar
Alan 71
Hi bsewell,
You asked about an 'inspector'.
You REALLY need to have someone very knowledgable about Lt-! cars take a look at this car. A 72 LT-! with a/c is quite a find if it's really as described. But, you need to be sure what you're spending your money on.
Why don't you pm Rowdy Rat (Stan) and ask for some suggestions of people he might know who can do this for you.
Regards,
Alan
Old May 13, 2011 | 05:44 PM
Mashman's Avatar
Mashman
The problem with A/C on LT-1's was that they would throw off the A/C belt at very high RPMs. To solve the "problem", they put standard 5600 redline tachs in the LT-1 A/C cars.
Nothing in the engine code tells whether or not it had A/C. Things to look for - does it have a washer bag? Does it still have the original alternator(non A/C would be 1100950, A/C would be 1100544)? Does it have the rear vacuum actuators for the Astro Ventilation?
I think what has happened is that an aftermarket A/C system (or one from an A/C car) has been put in. If the 6500 tach is still there, then noone has really tried to pass this off as a 'rare' 72 A/C LT-1.
And to the OP, if you're not aware yet about why the fuss over whether the car had A/C. 72 was the only year that LT-1's were optioned along with A/C, and only 240 were sold, so it's a very rare option, and that makes them collectible/valuable.
To 1972 LT1 questions
Old May 13, 2011 | 08:29 PM
Drew Papsun's Avatar
Drew Papsun
Hello bsewell,
What is the VIN?
What is the complete information on the engine pad stamping
V???? CRT ?
What is the trim tag information?
Post the answers for all the readers to see the answers.
Regards,
Drew Papsun
Old May 13, 2011 | 09:21 PM
rvazquez's Avatar
rvazquez
Plus I just re-read the original post and noticed you said it was a convertable, I don't really know how many people that ordered a vert would also equip it with a/c.We all know that in Forida a/c is allmost mandatory.
Let us know what you find out.
Regards
Roy
Old May 13, 2011 | 10:32 PM
Rowdy Rat's Avatar
Rowdy Rat
There's a 1972 LT-1/C-60 convertible currently for sale in the "Cars For Sale" section of the forum. It's a nice car and has done really well in NCRS flight judging. Asking price is around $75,000 which is actually a good buy for a car like this... Before the economy tanked, these were $100,000+ cars in similar condition.
Drew knows as much about the LT-1/C-60 cars as anyone I can think of and has been keeping a survey of them for years. He also owns a pretty darn nice one too!
Regards,
Stan Falenski
