corvette brakes
Scott
Anyway, I know the car has standard rubber brake hoses, so I'm going to be upgrading to stainless steel hoses (and replacing any lines that may have leaks which I haven't found any evidence of).
From reading it sounds like most of the issues with the breaks come from poorly designed calipers? Something about leaking seals... I'm not sure.
I was wondering if anyone had some suggestions about what I should upgrade my brakes to without breaking the bank (calipers, rotors, etc). I've been searching the net for different options. I've seen things from bolt on replacement kits that are equivalent to C6 brakes (very spendy) to some kits that cost as little as $500. I'm not looking for track performance, but something more reliable. I know this model is equipped with power breaks. I'm doubting that I need to replace the master cylinder or the power break system.
I've come across this kit on ebay, but I have no idea if it's any good. http://cgi.ebay.com/ebaymotors/Wilwo...Q5fAccessories
Thanks in advance for any tips!
Tim
Update:
I noticed VBP had been mentioned in a previous post. Their kits seem like pretty good deals! It looks like they come with new hoses, but it doesn't say if they're stainless or not.
http://www.vbandp.com/C2-C3-Corvette...-5-Brakes.html
Any reason to change out the rotors if nothing is wrong with them? Are these higher performance rotors or something? (trying to determine if I could just get the caliper upgrade kit)
The biggest problem for today's drivers is that the components in the C3's braking systems are 40 years old!!! There are things to make them better:
1) change out ALL of the brake fluid. DOT 3 absorbs moisture and most C3s' fluid haven't been changed out for many years (just added to as needed or when bled).
2) replace or rebuild the master cylinder. A simple device that has seals and valves which wear over time.
3) the rubber lines at each wheel are only good for about 10 years (max) without expecting problems [some potentially dangerous].
4) P-valve (or distribution block) can wear or get sticky. Easy rebuild or replacement.
5) owner's have little knowledge or experience at properly bleeding brake systems.
Air gets trapped in the calipers during bleeding and the calipers need to be rapped with a rubber mallet as they are bled to get rid of it. Also, the 'outlet' line from the calipers needs to be charged with fluid at the start so it will help suction the air out of the system. Lots of little 'tricks' to help get that trapped air moving and out of there. The Chevrolet Chassis Service Manual has a pretty good procedure to follow...if it's used.
Many owners, when confronted with brakiing problems, don't read up on how to make their existing system better; they just go spend a bunch of money on "bigger, better" parts...which when installed haven't done anything to fix the existing cause of their problems. It is really better to get the C3 system up and running as it should first. THEN if the brakes aren't adequate (can't imagine that for a street vehicle), bigger and better might actually improve what's there.
As little maintenance as most folks do on these old braking systems, I'm amazed they still work at all. Keep them in good shape and they work great, IMO.
I tinkered with mine and until I went thru the entire system from M/C rebuild to right rear with O ring seals has it performed exceptionally well. I now run silicone fluid and after 8 years, pedal is still nice and tight.
As others have said, it's lack of even basic maintenance at the root of brake problems on these cars, not design faults.
If you ask someone who has replaced every part of their braking system with brand new parts, and is having problems, they will say something like " This is crazy. It should just work. What a crappy design."
I think the real answer may be a little from column A, a little from column B.
Scott
Scott
Personally, I have found that Speed Bleeders, a small container that holds the tube below the level of brake fluid as the receptacle for the old fluid, and the two person method is best. My receptacle is smaller than the master cylinder reservoir, so I don't ever run the reservoir dry. But others swear by other methods, so pick your poison, but get the air out!
Pete
With DOT 5, it does not have the affinity toward moisture but does have an affinity for air or oxygen. If there is a breach, than it attracts air and you get a spongy pedal. My experience was that this gets worse at higher altitudes...like mountains. I live at sea level, so once my brake system was rehauled, it has remained solid.
I examined the brakes and determined that one of the calipers and the master cylinder had bad seals. I also figured out that the portioning valve had gone bad and the brake fluid had broken down because it hadn't been flushed in probably 15 years (just bled every time they pulled it out to drive it for the year). Reading your posts and doing some online research, I decided that DOT 5 brake fluid is the way to go for old cars. I wasn't confident that I would be able to adequately flush the system of DOT 3, so I ended up buying a complete set of stainless steel brake lines.
Here's what I'm now running...
Stainless steel lines
Braided stainless steel hoses
VB&P O-ring style stainless steel calipers (powder coated)
New master cylinder
New proportioning valve
VB&P supplied performance brake pads
DOT 5 brake fluid
The rotors appeared to have hardly any wear (couldn't even feel a lip on them). These aren't super high performance rotors or calipers, but braking performance is now awesome! HUGE difference over the old ones. Had the previous owner try it and she couldn't believe the difference.
Thanks for your advice guys!
By the way...
Anyone thinking about doing brake lines, some of the bolts going to the rear brakes are terrible to get out. Pre-bent lines are pretty much impossible to get to the front-right wheel without removing the radiator shroud (which is a much bigger pain that I imagined).
