Blower motor ground.
Old Jun 8, 2011 | 10:49 PM
Bad Bird's Avatar
Bad Bird
Default Blower motor ground.
Hi guys,
I'm still very thankful for the help I received for my wiper motor troubles. I took the advice of many posters and ordered the 1971 AIM and 1971 Chevrolet Chassis Service Manual. Unfortunately, due to living in Australia they have no arrived yet.
Another quick and stupid question, but is the little copper blade connector on the blower motor (as shown in the following picture) the ground for the blower motor? My blower motor doesn't run on any setting, and there is nothing plugged onto this connector.
Cheers guys,
Matt.
Old Jun 8, 2011 | 10:57 PM
...Roger...'s Avatar
...Roger...
No thats power going in to the motor , the ground is a separate spade that screws onto the case in 1 special spot.
Old Jun 9, 2011 | 12:38 AM
Bad Bird's Avatar
Bad Bird
Oh I see. It explains why it doesn't do anything if it's not getting power.
And you're saying the case of the blower motor is ground, and a spade connector bolts onto the case? The wiper motor is setup like that for its ground, I think.
Old Jun 9, 2011 | 08:20 AM
...Roger...
Yes the spade is screwed to the case with a sheet metal screw that must bite into the case.
If you look at the holes around the case you will see a couple that are smaller in diameter than the mounting holes,those smaller holes are there so a sheet metal screw can bite in and provide a good ground.
Old Jun 9, 2011 | 08:34 AM
Bad Bird's Avatar
Bad Bird
You're a good guy, thank you for the help.
It seems that Bubba really liked to tinker with wiring... I don't ever seem to get power to the motor, nor it is grounded to anything. Happy times await.
Old Jun 9, 2011 | 02:23 PM
7T1vette's Avatar
7T1vette
Get to clean metal on the motor flange under that connector and screw. If not, the paint will severely limit the current available to the motor.
To Blower motor ground.
