...a NOM (GM Goodwrench) 72' Vert , 4spd, white top. Color change from green to MM red - both tops, needs exterior paint touch up on the convertible top 'glass cover panel. Needs new seat covers, cartpet, door panels (the usual). Engine has about 32K miles on it, tranny, diff, running gear very excellent, could use A-arm bushings. Wiper door does not work, but is all there. Options: P/S only.
How is the frame and birdcage? Here is the value that Collector Car Market Review thinks it's worth. 15K might be a little high if it needs an interior redo but verts are worth more than coupes. Do you have any pictures to post?
Gary
1972 CHEVROLET CORVETTE 350-200hp (8cyl-4V) AT
Condition #5 #4 #3 #2 #1
Roadster 5825 11175 18025 24400 36425
Coupe 4275 8100 13975 19625 28150
Add:
350-255hp LT-1 15%
454-275hp (8cyl-4V) 30%
4spd manual trans 8%
Air conditioning 10%
Power windows 3%
Hardtop 5%
F-41 suspension 2%
Deluxe interior 3%
AM-FM stereo 2%
Tilt/Tele wheel 2%
Deduct:
Manual steering -3%
Thanks for that tip - I am going to look at it again tomorrow and had thought about bringing my tools, remove the door sills (if possible) to look under the kicks. The #4 body mount brackets were a little rusty. The metal edges under the pillar post trims were clean, no rust. Maybe I can get them to jack it up, pull the rear wheels and get in the #3 body mount cavities too. I forgot to look at the front crossmember last time - duhh.
Originally Posted by Mashman
No, that price actually seems kind of low. Are you sure there aren't any rust issues? I'd check the birdcage, kickups, and body mounts very closely.
Gary
Add:
350-255hp LT-1 15%
Power windows 3%
Hardtop 5%
F-41 suspension 2%
Deluxe interior 3%
AM-FM stereo 2%
Tilt/Tele wheel 2%
Deduct:
Manual steering -3%
I dont see how you can try to use this guide when the car is an NOM and is the wrong color. None of the price guides estimate those deductions.
With those issues and the repairs it needs, I dont think the price is that good, personally. Look a little harder and spend $20k for a similar condition car with the correct motor at least.
Thanks - I don't really care about the NOM issue in this case since it is relatively new. The glass is all original. Color change is not an issue either - personally I had considered changing it to a Corvette blue color. Given - I've got 4K work to do in the interior. I already have Al Knoch seat covers, install kit and foam though
I wouldn't really disagree with you, but frankly I've never seen a running 72' vert 4-spd go for 10K lately. There's another local 72' Vert 4-spd, color change black (really incorrect color) from white, same options or lack of, and a way-worse interior, a hacked up engine compartment and a rough running 'origianl' motor. The guy is firm on $18.5 - yep, he probably won't get it.
Originally Posted by 7T1vette
Yes. 15K is too much for that car. I don't see more than about $10-11K for that car...assuming that the top doesn't need replacing.
Hi mar,
Just because YOU don't care about the matching motor and paint doesn't mean you should pay the higher price for the car because the owner has priced it as though it does have the proper engine and paint.
You're giving him money he shouldn't be getting.
Sorry!
Regards,
Alan
Alan - thanks very much, maybe I can negotiate 13.5. Would that be fair??? A lot of cars are changing hands w/o correct engines and a lot of 'correct' engines are in fact a really GOOD re-stamp (I'm told). Granted 'matching' is best.
mk
Originally Posted by Alan 71
Hi mar,
Sorry!
Regards,
Alan
Hi mar,
Sorry!
Regards,
Alan
Alan, as usual, hits a home run. Exactly what I was going to type. (thanks, A). Just because it's not important to you dont mean you should go ahead and pay for it anyway. Use the market to your advantage. Anything less is paying extra to be lazy.
Thx very much! That's why this is such a great Forum - a huge brain-trust based on 100's of years collective experience and observation.
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
NOT to change the subject, but in your first picture above - WHAT is that creature behind the fence/gate, standing on its hind legs? Sasquatch ? a bear ?
The interior needs a lot of work (maybe not a lot of new parts, but certainly a total dismantle, cleaning, re-dye, new carpet, etc.); the engine compartment is in dismal shape. These two things would lead me to believe that the car had not been maintained that well. Yes, the hardtop is a plus IF the soft top is in good condition and functional.
I just don't see much more than $12K there...but that is only one person's opinion. The vintage car market is really down right now, maybe you are the person to get it going positive again!
mk
I don't think you need to worry about buying a re-stamp in that price range . That usually is only worthwhile for the bad guys on rare high optioned , high HP and high dollar cars .
Given the fact it's not the original engine or even a 'correct' engine, interior is rough and engine compartment rather scruffy. No more than $11K, maybe less depending on the condition of the frame, etc.
So far as "proper engine" as mentioned in another post, I'm not sure what that means, 'original' or just 'correct'. A 'correct' engine may fetch a bit more but still leaves it as a NOM.
No idea what a NOM "should" sell for. Some buyers don't care, others given a choice of two would rather have a pieced together 'original' block than a solid 'correct' block. I'd suggest checking out cars for sale at Carlisle to get an idea of what the current market is. I did hear of a NOM selling for $15K last year at Carlisle with a few buyers interested. It was probably in better condition though...
Good eye!! I think you might have discoverd big foot!!
