Hi? I have just changed my radiator hose upper and lower hose with new coolant and new thermostart. While the car is running (and around 180 to 200 degree), i tried to squeeze the upper radiator hose and it hard. It hard to squeeze. What could it be. This happen during during the 10 to 15 minute of the car running/idling.
I have a 82 corvette with a chevy 400 small block.
Hardness of the hose is not a recognized measurement of anything. It's an indication that the cooling system is gaining pressure, exactly what it is supposed to do as the engine temp increases causing the pressure to rise to the maximum the radiator cap allows. If you have concerns check your rad cap for correct rated pressure for your application and have it tested to ensure that it is releasing at that pressure. But frankly, I don't believe you have anything wrong.
There is no pressure hose. The pump is a centrifugal flow pump, it doesn't produce enough pressure to lift the needle on a gauge. The pressure in the cooling system is a result of the coolant expanding in a closed system. The pressure is equal throughout the system and is regulated by the pressure cap.
...and to add the final explanation: the system is designed to operate at a certain pressure, usually 13-15 lbs sq in. which prevents the water/coolant from boiling over. That allows your car to operate at higher temps than would otherwise be the case w/o the pressure, especially when you turn the car off and the water temps typically rise for a few minutes ...close to the boiling point. Keep your eye on the temp gauge and see what it reads during normal driving. Also, does it 'boil' over? If so, that could be an indication of a weak radiator cap, or another problem of you system: partially plugged radiator, sticking thermostat, bad fan clutch, etc...
before i worked on the upper and lower hose, the car overheat above 200 degree and the as you continue to drive it keeps going up to the red zone. i don't have a clutch fan, i have a flex fan attach to the engine and an electric fan front of the radiator.
Most people here will probably tell you to ditch the flex fan and go back to stock with a fan clutch (better performance and safer). Is the radiator fan shroud and all that still in place? We'll assume the thermostat is working (new) and is in the right direction .... you may want to remove the radiator cap while it's running (cool) and see if you see bubbles or get your nose down there and sniff for combustion fumes, which could indicate a headgasket leak. Otherwise, on these older cars, the radiators themselves often need to be taken to a shop and 'boiled' out. Anyway, those are some ideas.
Of course the explanation isn't complete without mentioning the difference between older systems and coolant recovery systems. Older cars always needed an airspace above the coolant in the rad to allow for expansion. In cars with a coolant recovery system the rad is filled completely. When the coolant expands it flows into the recovery tank. When the engine cools the coolant contracts and draws the fluid back from the recovery tank. This way the rad is always completely full. And that's why there are cold and hot fluid level marks on the tank. This is also why you can not fill a rad from the recovery tank when there is a significant size leak. Instead of sucking the fluid back from the tank it simply pulls air in via the leak hole.
Yes, ditch the flex fan, re-install the clutch fan and pull the rad and have it professionally cleaned. Antifreeze that has been left in the system too long (over 2 yrs) will have it's silicates leach out and plug the tubes in the core. If the temp is climbing slowly over the 200 mark and you don't have coolant being pumped out the overflow continuiously it's not likely to be a compression leak into the cooling system.
it a brand new three rows radiator. yes the the fan shroud is in place.
Mark G
Help pls. more problem. i started the car today, it idle just fine, i drove it for no more than ten minutes. i parked the car. as i was walking away from the car i have a pop sound. when i turned around i saw coolant on the floor. i opened the hood and the upper hose that i mentioned was hard burst open. what is going on?
Since you have new hoses and radiator, then your radiator cap failed. Get a new one.
You shouldn't get that much pressure in 10 minutes, sounds like you have a crack in the heads or block or a bad head gasket. If it really is a sb 400, then they also have other headgasket issues, google for them.
If it is older, you may want to flush and descale it too.
Themostat quality is an issue these days so always test one first.
Try starting with the cap off rad completely full and see if you get a lot of air pushing the fluid out when cold or rent a cooling pressure tester to test for leaks.
Run without the tstat until you get things sorted out.
A recap and update. My 82 corvette will start up just fine and runs just fine. But the longer it idle the temperature gauge goes up and it can go up all the way close to red line. This also happen when i drive it. When i start driving, it drives fine and the longer i drive the temp goes up close to red line.
One day i started the car after five minutes i tried to squeeze the upper radiator hose and it was hard and tense.
Couple of days later , i started the car and drove it for no more than ten minutes and i parked the car. As i was walking away from the car i had a burst. When i turned around i saw coolant on the ground. Opening the hood the upper radiator hose burst open.
Today i replaced the upper hose. A friend told me to start the car without the radiator cap and see what happen in four minutes. I started the car and it ran for four minutes nothing happen or water spraying out of the radiator.
After four minutes i put back the radiator cap, in the ten minutes of the car just idling, the upper radiator hose poped out of the thermonstart inlet pipe.
This is what am facing. Pls help. Ideas and suggestoins are welcome.
Is this a fan issue, radiator issue or cooling system issue or it is engine timing issue or internal engine issue?
Have you tryed to run the engine without the thermostat or whit a different one?
Do you have an "airlock" in the upper hose or the cooler that needs to be bled out?
A compression test will show if you have a leaking cylinder that pumps up the cooling system with air.
Also look for small drops of water/rust stains on the plugs.
I use to jack up the passenger side of the car quite high when filling the cooling system.
I fill it in the expansion tank with the radiator-lid off.
When all the air is out and there is only cooling fluid coming out of the radiator i put the lid back on.
If there is a lot of air in top of the radiator/hose it will expand a lot.
Start with the basics. You need to determine if the system is flowing water or not, if it's plugged, how much pressure it's holding etc.. Is the bottom hose collapsed when your upper hose has pressure? Have you pressure tested the coolant system, including the cap? (If your cap is working correctly, you shouldn't be able to build more pressure than the cap will allow) Have you run the car with the cap off to see if you have flow across the radiator? Does the coolant smell like exhaust? Is the shroud and bottom air deflector in place on the car (these parts help keep things from getting too hot when your driving the car)?
If you can't do these things, you might be better off finding someone who can help, or even taking it to a shop.
Have you changed out the thermostat yet? You have this thread on a couple of the Forums and I have yet to see that you changed it. The T-stat is most likely your problem...even if you just bought it. (well, especially if you just bought it... )
I had my radiator cap tested. it say on the rad ccap 16lbs but it start to release at 11lbs.
yes i have ran the car without the rad cap on. the water inside the rad is moving and for four minute without the cap no water comes out or spray out.
