Gas smell
Old Jul 5, 2011 | 10:39 AM
1970StingrayScott's Avatar
1970StingrayScott
Cruising
Default Gas smell
Dear Fellow Corvette lovers
I am new to this and own a 1970 Stingray for 10 months
It has a ZZM 355 hp GM crate engine. I have 2 questions to ask and appreciate your help in advance
1. I have a persistent gas smell when the car is idling or parked in the garage. I can find no leak and my mechanic can't find anything wrong. Any thoughts?
2. Yesterday after filling up the gas tank, my fuel gauge went from full to empty and stay at empty. Occasionally it swings baakc to half full and quickly goes back to empty. Suggestions?
Scott
Old Jul 5, 2011 | 11:47 AM
cm2dinger's Avatar
cm2dinger
1) your carb is running rich but thats ok its a lovely smell.
2) your sending unit is probly boned
Old Jul 5, 2011 | 12:07 PM
TxBolt's Avatar
TxBolt
I JUST had the exact same problem with a crate engine in my 79.
The fuel injected engine was still connected to the Vapor Canister for some reason. Since there's no carburetor for it to go back into, it was just spitting out fuel vapors into the air (and mostly into me when I was driving). We just disconnected the line to the Vapor Canister and plugged it. Problem solved.
I hope that works for you as well as it did for me.
(can't help with the fuel gauge though... sorry)
Old Jul 5, 2011 | 12:25 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
check your steel gas lines going from carb to tank,
if they are orginal,
they are probable nearly rusted thru from the inside and not visible.
but gas will weep out where you cannot see it.
I would advise to change them if orginal.
Gauge is a completely different problem.
Old Jul 5, 2011 | 02:50 PM
Alan 71's Avatar
Alan 71
Hi Scott,
I believe I'd check out the ground connection on the fuel sending unit.
You can just get to it by opening and dropping the spare tire tub. The sender is a little to the right of center under the tank.
Good Luck!
Regards,
Alan
Old Jul 5, 2011 | 04:13 PM
Mashman's Avatar
Mashman
If you've plugged the line from the gas tank to the canister, you need to make sure you switch over to a vented gas cap.
Old Jul 5, 2011 | 11:03 PM
TxBolt's Avatar
TxBolt
Now, why didn't my mechanic tell me that?
That explains the hiss from my gas cap yesterday. However, does a vented gas cap just open the door for the fuel smell again and we're back where we started?
Old Jul 5, 2011 | 11:53 PM
spdrcr29's Avatar
spdrcr29
The last time I noticed the smell of gas, my vette caught on fire....75% of engine compartment burnt up. Now i'm in the middle of a body-off restoration because of it. Luckily we were able to get the fire out and did not have a complete melt down, but it still did enough damage...
Old Jul 6, 2011 | 06:54 AM
srosa75's Avatar
srosa75
I had the same smell and this fixed it. Run your hands along the top of the frame on the passenger side where the gas line runs and see if you get any gas on your fingers that has weeped out. Doesn't have to be much to smell fumes all the time.
Old Jul 6, 2011 | 07:26 AM
Paul L's Avatar
Paul L
I'll throw in a couple based on my experience over the last two weeks.
This is the fuel pump end of the rubber "S" hose, frame to pump. The car ran. Symptom: slow drip when car parked.
This fuel pump had a small rupture in the diaphragm. The car ran. Symptom: same as above but also visible film of fuel seeping from upper vent holes.
To Gas smell
