Exhaust Questions - Emissions
Old Jul 8, 2011 | 06:51 PM
tterz's Avatar
tterz
Default Exhaust Questions - Emissions
The smog rail on the passenger side of my motor has rotted and detiorated. Are the smog rails needed in order to pass emissions or can I remove them all together and plug the holes until I get new headers for the vehicle? Or should I attempt to purchase a new smog rail for this original header?
I do not plan on buying new headers for a while and I would like to get it emissions tested sooner than later. What is the official name for these rails connected to the exhaust manifolds also for internet surfing purposes?
Thank you,
TTERZ
Old Jul 8, 2011 | 06:57 PM
Alan 71's Avatar
Alan 71
Hi tt,
They're called A.I.R. Tube Assemblies, and they're available from various venders.
Regards,
Alan
Old Jul 8, 2011 | 07:02 PM
tterz's Avatar
tterz
Alan,
Are they important for emissions passing? Is there anything specific I need to know in ordering a new one? Can I block the wholes and still pass emissions or are they needed?
TT
Old Jul 9, 2011 | 04:06 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by tterz
Alan,
Look at it this way...your emission control hardware is thirty something years old while emission control test equipment is probably current and high tech enough to test 21st century built vehicles. I suspect it will pick up any emissions that calibrate beyond their limits for your year.
A.I.R. (air injection reactor) squirts oxygen into hot exhaust gas to burn unspent hydrocarbon and carbon monoxide gases. Actually the oxygen completes the combustion process. So if you remove the A.I.R. hardware (pump, diverter valves and pipes), your exhaust gas will emit unburned carbon monoxide (stuff in cigarette smoke taken into the lungs by those that inhale) and hydrocarbons.
Can you pass emissions? I'm not sufficiently familiar with the emission test equipment to say and don't worry about it since our state does not test for automotive emissions.
Old Jul 9, 2011 | 07:51 AM
Alan 71's Avatar
Alan 71
Hi tt,
It's difficult to answer your questions not knowing what year your car is or what state you'e in.
Perhaps filling in your profile will help someone familiar with your state's rules give you some guidance.
Regards,
Alan
Old Jul 9, 2011 | 10:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What model year? I'm thinking the 81-82 mainifolds/AIR are a unit.
Old Jul 9, 2011 | 01:40 PM
tterz's Avatar
tterz
Sorry.....I own a 1980 Corvette with an L48 350 motor. I know that it has to be emissions tested because it is newer than a 1976 model vehicle, so I am attempting to do my research to find out what I specifically need to do in order to pass emissions in the state of Indiana....Lake county specifically.
Thanks,
TTERZ
Old Jul 9, 2011 | 02:10 PM
C3-PO's Avatar
C3-PO
Default i got your motor too ...
i've got your car too here in California. mine has passed with better than current ranges for NOx/Co/CO2 the 31 years that i've had it. last year the CO rose to the max limit of the range. probably because the platinum in the (original) catalytic converter is getting old and cannot gather the excess CO any more. The A.I.R. tube is important. having one side blocked off will have a profound increase in emisssions, not to mention unequal back pressure in the mainfolds and an increse in raw gas going into the catalytic converter which clogs it up even faster.
if you fail the test, you'll have to replace the part and do it again. otherwise you'll be tagged as a gross polluter and spend goobs money to replace the smog systems components and go to get recertified at the DMV (fun ....). you can still dirve your car until the next time, then they wil not re-register your car until it passes. i'm not sure if penalties are involved, but in California they will definitely hit you up for big bucks.
To Exhaust Questions - Emissions
