Cleaning Engine Bay - Advice
Old Jul 8, 2011 | 08:08 PM
77vetter's Avatar
77vetter
Default Cleaning Engine Bay - Advice
I want to power wash my engine bay to clean it up a bit. I have a 1500psi electric power washer I was planning on using. Anything I need to be concerned or aware of before I start tomorrow?
Thanks!
Old Jul 8, 2011 | 08:46 PM
Vette5.5's Avatar
Vette5.5
At the very least, think I'd wrap the distributor in some plastic. 1500 psi sounds like lots of pressure for this duty, and probably going to rip some engine compartment paint off. I usually do this when the motors out, then some Super Clean, a light brushing and garden hose rinse.
Old Jul 9, 2011 | 01:36 AM
couperdecar's Avatar
couperdecar
I have never been happy with electric power washers. Went through 4 of them over the years. I've got a gas now. I think that 1500 rating is when you put the attachment on to really focus everything into a single stream. If you are using the 'fan' attachment you 'll have just enough pressure to blow any degreaser or soap off. Thats about it. I've never covered anything in my engine compartment , but I keep the jet away from the distributor.
Old Jul 9, 2011 | 01:57 AM
3JsVette's Avatar
3JsVette
I agree with Vette5.5
If you use the power washer you will most likely take too much off including lots of paint.
How bad is the engine compartment? I wouldn't start with the power washer. You can always resort to that if there are real trouble spots. Get a good degreaser (I have had great success with Greased Lightning) and soak everything. Give it some time to do it's job (you can always help things along with a brush in the really bad areas). Then rinse with a garden hose that has a good nozzle (being carefull of the carb and distributor). That should do it. Good luck with what ever you decide.
Old Jul 9, 2011 | 04:21 AM
thegavel's Avatar
thegavel
When I was car detailing full time, I learnt to have the engine running whilst cleaning it (being very careful,of course). It's easier to keep it running than trying to start a wet engine. I also use a product called CT-18 degreaser(not sure if you guys have it, but it's here in Oz) Just my 2 cents.
Old Jul 9, 2011 | 07:45 AM
Alan 71's Avatar
Alan 71
Hi 77,
Remember that rust will become a big problem as soon as you're finished because many of the metal parts are being protected now with some grease, oil, or dirt. Once they're clean, the rust will start overnight.
Do you have some plan in mind to deal with that?
Regards,
Alan
Old Jul 9, 2011 | 08:06 AM
nutsy's Avatar
nutsy
just cover the carb and dist. i dont leave engine running . this may cause water to be sucked in through the carb.
Old Jul 9, 2011 | 09:39 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
What no one wants to cover the alt ? ? I always cover Dist ,Carb,Alt,Jusst in case... and dont use a lot of water in those areas...Also if you cont want all the crap in your driveway, go toa local car wash early so no one can see you greasing up there carwash...lol
Old Jul 9, 2011 | 01:36 PM
Phil Zell's Avatar
Phil Zell
Take a can of WD-40 with you to the car wash. If it won't start after washing, remove distributor cap wipe out and spray with the WD-40, replace cap. It Works !
To Cleaning Engine Bay - Advice
