75 wiring issue
Old Jul 11, 2011 | 12:53 PM
SonnyLynnVick75's Avatar
SonnyLynnVick75
Default 75 wiring issue
Wiring problem! i just put in a new dash wiring harness and connected it to the engine side but im getting no power to the inside, im thinking the engine side hookup is bad possibly what is the name for this part/ harness is it the engine harness or what? also what do you guys think it may be?
Old Jul 11, 2011 | 01:06 PM
...Roger...'s Avatar
...Roger...
In the engine compartment you have an ignition harness and a headlamp harness.
Old Jul 11, 2011 | 01:17 PM
...Roger...
Do you have all your 10 reds plugged in on the engine side of the bulkhead connector ?
SonnyLynnVick75
Yes but do both of these go into that single block? or what? i dont need an entire harness i just a new block or whatever harness th block comes with
Old Jul 11, 2011 | 01:22 PM
...Roger...
Yes they both assemble together and go on as one.
Old Jul 11, 2011 | 01:23 PM
SonnyLynnVick75
I believe i do
Old Jul 11, 2011 | 01:28 PM
SonnyLynnVick75
Well crap, see my connector looks similar to the one pictured dirty, connectors somewhat loose etc. do i have to buy both harnesses?
...Roger...
Send Noonie a PM to get involved in your thread,he has a 75 and was just where you are and should be able shed some light. I have a feeling your problem might be the funky way the 75 brings power into the bulkhead with the multiple connections made under the brake booster which also includes the fusible links.
http://forums.corvetteforum.com/c3-t...hunt-lead.html
Old Jul 11, 2011 | 01:47 PM
...Roger...
I wouldn't buy anything yet,one wire unplugged will kill the power.
Do you have power at the back of the alternator or any of the large red wires ?
Old Jul 11, 2011 | 07:17 PM
noonie's Avatar
noonie
All the red 10ga join in front of the bulkhead. Solenoid, Alternator, Bulkhead and Fan Relay
Old Jul 12, 2011 | 06:42 AM
SonnyLynnVick75
im getting power to the bulkhead ive tested it on the "pickup" side and im getting power but it seems as if the loose prongs in the bulkhead arent connecting properly with the new dash harness
To 75 wiring issue
