Fender Replacement
Thanks!
Two volumes for C3s. Purchase both.
This is reasonably good if you can find a copy. It may be out of print.
71 rear fenders are SMC; most of the rest is press molded polyester. If you purchase repair materials compatible with both types of fiberglass, you'll be fine.
I started with the Ecklers DVD video (#2 I believe). I recommend it, even though it's kind of pricey. What I did after sanding the paint off, down to the fiberglass, was to carefully take a cut-off tool and make an incision down the length of fender at the gap where the fender and the upper surround meet. I used the technique that Ecklers promotes which is to use a wide chisel and a 4lb hammer and work your way along the incision (basically along the body seam) from one end to the other giving sharp blows. Doesn't seem like anything is happening until suddenly "thud" and the seam breaks free (just like splitting a wide section of wood). I used a toothed 2" wide cement/brick chisel that worked great. I had it anyway for other uses. Then you just remove other areas as needed. I know other guys use the heat gun method to 'soften' up the bonding agent and it seems to me that this would work better, but I haven't had a need to try it lately. So if it were me, I'd apply the heat gun method and the chisel method. Should come off pretty easily.
To install, grind down the bonding agent on the existing filler strip and get the 'right' stuff from Ecklers or another shop. I used a hand sand blaster to blast the areas where the bonding agent would adhere to on the backside of the fender. Looking at my original, it looked like the factory did the same thing to give the fender something to 'bite' to. Get it to fit like you want it, I used a couple screws in a few places to locate it where I wanted it, then using masking paper in the shape of a cone, put the bonding agent in the cone and apply the bonding agent like cake maker would apply frosting to a cake. Put your fender on and locate using a couple screws. Apply tape or use whatever clamping means you wish to clamp into place accordingly. Be careful not to clamp too thight that you get 'divits' or low spots in the new panel from clamping devices. Fill in whatever screw holes you need to afterwards. I "V'd" out the gap and applied fiberglass filler and matt along the seam to make a nice and 'invisible' repair. Then, grind/sand down as needed. Apply 2k primer and once dry, apply your filler over that and bodywork as needed like you are used to doing.
One key thing I would pay attention to if you want your final product to look 'factory' as much as possible is how the new bonding agent squished out of the seam. What I mean by that is, take a look at your panels now where they meet the body. You will see that they applied a bead of bonding agent, then the fenderd and other parts. Some of the bonding material 'squishes' out. Try to add enough, but not too much that it too squishes out on your repair, but not so much that it seems un-natural. Don't take your finger afterwards and smooth it down or it will, again, look like an aftermarket repair. Undercoat when finished.
Good luck,
Mark G
I'd think that if you can replace the fender at the original bonding strip your job will be much easier.
Here's a couple of pictures to show the strip's location, hopefully they'll help you. Note that the front clip is really 3 main pieces... the hood surround, and 2 fenders; then the lower valance is added.
Good Luck!
Regards,
Alan
Note: When I said in my above post 'make an incision down the length of the fender' I should have indicated the incision should only be about 1/8" deep. Don't cut the bonding strip. Just grind down the depth of the panel you are removing. A grinder would work also.
Mark G
Glassing in the seam after bonding.
After epoxy Primer.
ikwhite
Good luck.
Glenn
EDIT: Here's the link.
http://www.youtube.com/watch?v=0E6YC5Iys_I
Itchy fiberglas gives me fits and the less grinding dust, the better.
Mark G
