need help replacing ignition wires
Old Jul 23, 2011 | 02:01 PM
Frank.luvstingrays's Avatar
Frank.luvstingrays
Default need help replacing ignition wires
hi,
I need some help with replacing ignition wires on my 70 350,
I really don't know where to start can someone post a step by step instructions I have a stock setup and i'm keeping that way. really could use some expert advice.
thanks in advance
Frank
Old Jul 23, 2011 | 02:27 PM
Alan 71's Avatar
Alan 71
Hi Frank,
First a few questions... what makes you think they need to be replaced ... have you bought a new set yet... and if so are they pre-cut to the proper lengths?
Regards,
Alan
NICE PICTURES!
Old Jul 23, 2011 | 02:34 PM
Frank.luvstingrays
Yes Alan i did buy a set of ACDelco wires GM# 88862452
Frank
Old Jul 23, 2011 | 02:55 PM
Frank.luvstingrays
it looks like i have to remove the boots on the wire that plug into the coil & cap.. and then try to pull the new wire thru that grommet connected to the chrome shield.
Old Jul 23, 2011 | 03:13 PM
Paul L's Avatar
Paul L
NO! Just pull the grommet out. It has slits for the wires.
Roco71's Avatar
Roco71
One at a time.
Old Jul 23, 2011 | 03:16 PM
rcread's Avatar
rcread
The wires for the front plugs route through the motor mounts. When I did mine, I got cut-to-length wires, fed them through the motor mounts and then attached the ends. It's a tight fit through the mounts.
Old Jul 23, 2011 | 03:23 PM
Frank.luvstingrays
can anybody tell me which cylinder has the longest spark plug wire i would like to start with the longest first.
Peace
Frank
Old Jul 23, 2011 | 03:27 PM
Alan 71's Avatar
Alan 71
Hi Frank,
The rubber grommets slip up out of the shield support. You'll then see they're split to allow the wires to be inserted.
Run the wires one at a time starting with the front. Take the #1 wire loose at the distributor and pull it from the spark-plug end until the distributor-end passes through the front engine mount. It WILL fit. Put the new one in by pushing it through the engine mount and pulling it to the distributor. This works for the front 2 wires on each side.
As you begin to work you'll see there is a wire holder at the rear of the block on each side that holds all four wires on each side. There is also a small clip on each side that is fastened to an oil pan bolt and hold 2 wires.
You may also find a boomerang shaped heat shield on each side behind the exhaust manifolds on each side. (sometimes they're missing).
The rear four wires are much easier.
Be very careful because it's easy to put the wrong wire on a plug or distributor tower.
It's not an 'easy' job but not too difficult either.
Good Luck!
Regards,
Alan
PS: I mark each wire with number to be sure.
PSS: Other posts with good suggestions while I was typing.
Old Jul 23, 2011 | 03:39 PM
mds3013's Avatar
mds3013
I believe #2 will be the longest with the Corvette shielding. This diagram just shows proper firing order but you can see when the wires are run through the shielding the general length of each wire in relation to the others. Hope it helps. mike...
Old Jul 23, 2011 | 04:02 PM
Frank.luvstingrays
Originally Posted by Alan 71
Hi Frank,
Good Luck!
Regards,
Alan
Thanks Alan
very helpful info
Peace
Frank
Old Jul 23, 2011 | 04:06 PM
Frank.luvstingrays
Mds,
I believe your right!!
I just started to taking off all the shielding & i'm on the hardest side passenger AC on r/h side..
Thanks for the info..
Peace
Frank
Old Jul 23, 2011 | 04:09 PM
Frank.luvstingrays
okay i'm on my way 4:10 is the time here
see how long it takes me
thanks all for the help
Peace
Frank
Old Jul 23, 2011 | 08:01 PM
Frank.luvstingrays
Default tough job
well I slit (cut) a new wire on the first try plug wire! #2 all others are in.. I've got to get another wire from the auto parts... It was a bitch the r/h side metal shield is much harder it has a bigger bend the plug wire caught up on the shield just when it came out. my hands are so cut up and not to mention sweating may *** off..
Peace
Frank
Old Jul 23, 2011 | 09:34 PM
7T1vette's Avatar
7T1vette
All that shielding and hardware was definitely meant to be installed out of the car! Not a job for the 'faint of heart'.
Old Jul 24, 2011 | 11:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...can anybody tell me which cylinder has the longest spark plug wire i would like to start with the longest first....
Pull #1. Compare the stock length to your replacement set, matching the closest length. Continue removing, matching length, installing one at a time.
Old Jul 24, 2011 | 01:43 PM
Frank.luvstingrays
I bought my car 8 months ago didn't really know when the last tune up was done, & I just had to know what was installed and to try to determine how long they where in the car.
It's kind of a thing I came accustomed to when purchasing a new car (old) having sad all that!! Parts installed previously were much better quality!!!
OEM ignition wires & cap with Blue Streak Rotor points looked pretty good not much wear also looked OEM.
I replaced plugs with ACDelco R43S installed where AC R44 with Accel points & condenser.
All ACDelco parts are all made in mexico I will never use ACDelco again
very cheep quality.
well I'm still not done, hear are some pictures You can see the original spark plug wire hear it's #4 cylinder it should be easyer to do #4 then #2 cylinder
Hear is the cut wire.. BTW The Auto parts store will have a new replacement wire for me tomorrow afternoon
old spark plug
To need help replacing ignition wires
Old Jul 24, 2011 | 02:24 PM
Frank.luvstingrays
hi,
buy any chance this my sound pretty stupid but how can I hook up my engine analyzer if the battery is behind the seat.
hear is a master hookup Diagram of my analyzer
Can anybody suggest what would be a safe hookup without using the battery?
Peace
Frank
Old Jul 24, 2011 | 02:52 PM
Alan 71's Avatar
Alan 71
Hi Frank,
You can use the positive post coming off the alternator.
The one with the black rubber boot.
This works for the timing light too.
Regards,
Alan
Old Jul 24, 2011 | 03:51 PM
Frank.luvstingrays
Hi Frank,
Regards,
Alan
Thank you Alan
Peace
Frank
