T-Tops
I was wondering if anyone knew how to fix this problem, my rightside T-Top is not lined up properly from the back. What I found mostly on the forum search was for the sides of the T-Top, not the back portion alignment. I have provided a picture, hopefully this helps my explanation.
http://smg.photobucket.com/albums/v1...t=102_2437.jpg
The four mounting points for the top do control the front to back position too.
The outer rear position is controlled by the tri-angle screw/pin in the body halo. Turning that screw/pin in and out moves the top panel backward and forward. The front outer pin needs to be loose when you do this.
I have everything loose, and set the top for center and rear gaps. Tighten the 2 outer points, and then check for 'height'.
I then move the screw/pin up and down with the 2 plate screws. Then I set the center height by shimming the 2 center 'tongues'.
Good Luck!
Regards,
Alan
PS: Whoops... my explaination was for solid early roof panels... don't know about later glass panels.
The AIM has a diagram of the receivers being installed and a note about correct latch,
