Steering column: dye or paint?
Old Jul 29, 2011 | 11:25 AM
KevinG's Avatar
KevinG
Default Steering column: dye or paint?
My steering column is currently bright blue and am doing a black interior conversion. So far I have lightly sanded the column with 500 grit paper and the part that has the ignition key cylinder seems to be metal since the original paint was almost all gone from that section already. Not sure if dye will do a good job covering aluminum.
What should I use? Corvette America dye or a black paint? If its paint should it be gloss black or satin black?
Old Jul 29, 2011 | 11:47 AM
gkz's Avatar
gkz
All metal parts of the interior I primed then used the same dye used on the plastic parts. I used all SEM products purchased from an auto paint store.
Old Jul 29, 2011 | 12:08 PM
7T1vette's Avatar
7T1vette
It's OK to use dye for that stuff. Interior dye does not adhere to metal as well as paint. But, since that part will not see much wear (as long as you can find the key slot ), It should be fine. I used my interior dye to recolor the outer portions of the horn button and have had no problems with it.
Old Jul 29, 2011 | 12:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
SEM will cover metal.
Old Jul 29, 2011 | 10:18 PM
Clubby99's Avatar
Clubby99
Dye is really nothing more than paint with flex additives.
Old Jul 29, 2011 | 10:42 PM
noonie's Avatar
noonie
Acrylic lacquer to be exact and millions of metal cars were painted with it.
Old Jul 29, 2011 | 10:55 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
im sorry you think a black interior is better then blue but if you want to do something that silly go to your local hardware store and get some semi gloss black and go have fun
Old Jul 29, 2011 | 11:00 PM
Alex/plus's Avatar
Alex/plus
im sorry you think a black interior is better then blue but if you want to do something that silly go to your local hardware store and get some semi gloss black and go away
What the !!!!......"HUH"
Old Jul 30, 2011 | 12:27 AM
mrmagrath's Avatar
mrmagrath
I primed my steering column, horn button, seat back seat belt bezels, rear compartment hinges, etc, and shot SEM on them. As mentioned above, it's regular paint with flex agents.
Old Jul 30, 2011 | 06:20 AM
Ralphbf's Avatar
Ralphbf
My steering column and counsel need help.
The column has paint missing off the top and the console
needs to be repainted too.
What shade of black do I need?
How about the dye?
Ralph
Old Jul 30, 2011 | 09:04 PM
ikwhite's Avatar
ikwhite
Just finished rebuilding my column and I primed with PPG epoxy and painted with PPG Single Stage black.
ikwhite
To Steering column: dye or paint?
