Horn Button
Old Aug 11, 2011 | 12:37 AM
u2bdet's Avatar
u2bdet
Default Horn Button
Looked in the AIM , catalogues and I'm stumped , how is the horn button assembly ,emblem,retainer and ring ,held together ? The parts all stack up nicely on the 3 pins ,but how is it all secured ?
Thanks ,
Neal
Old Aug 11, 2011 | 07:50 AM
Jim Shea's Avatar
Jim Shea
The pins are spun over. I would try to spin them over and then apply a dab of JBWeld on the tip of the pins. The production spun over heads are known to fail if you pry on the outer cap #11 when trying to remove the the horn cap assembly from the steering column. You want to reach under the outer cap #11 with the blade of a screwdrive to pry directly between the metal retainer #9 and the upper horn contact #7 (they just snap together.)
This blowup picture in the horn cap area is typical of Corvettes through the years.
Jim
Last edited by Jim Shea; Aug 12, 2011 at 10:32 AM. Reason: Clarify removing the horn cap
Old Aug 11, 2011 | 04:48 PM
u2bdet's Avatar
u2bdet
Default Thanks
Thanks Jim, when you say "spun over" do you mean drilled or tapped out so the hollow pins expand holding the assembly together ?
Neal
Old Aug 11, 2011 | 05:19 PM
scottyp99's Avatar
scottyp99
Neal
Yeah, what does "spun over" mean?
Scott
Old Aug 11, 2011 | 07:53 PM
Jim Shea's Avatar
Jim Shea
Just a smooth, flat, spinning tool that mashes the end of the pin so that it expands and captures the three parts together.
Jim
Old Aug 12, 2011 | 12:35 AM
u2bdet's Avatar
u2bdet
Thanks again Jim ...looks like another job for Mr.Dremel
Neal
Old Aug 12, 2011 | 10:06 AM
BTGRN75's Avatar
BTGRN75
St. Jude Donor '11
Originally Posted by Jim Shea
The pins are spun over. I would try to spin them over and then apply a dab of JBWeld on the tip of the pins. The production spun over heads are known to fail if you pry on the outer cap #11 when trying to remove the the horn cap assembly from the steering column. You want to reach under the outer cap #11 to the metal retainer #9 that snaps into the upper horn contact #7.
Jim
"reach under the outer cap #11 to the metal retainer #9 that snaps into the upper horn contact #7"
...........and then??
Old Aug 12, 2011 | 10:33 AM
Jim Shea's Avatar
Jim Shea
See above, I tried to clarify the removal procedure.
Jim
To Horn Button
