sagging hood
Old Aug 31, 2011 | 09:28 PM
fzfox's Avatar
fzfox
Navigator
Default sagging hood
Ok all you C3 owners- I just completed restoration on 73 vette, typical HOOD SAGGING in the middle when closed. What have some of you used to put under the hood between the inner fender lip/ledge to lift it back up so that it doesn't look tacky? Thanks, Lonnie
Old Aug 31, 2011 | 09:57 PM
Bugman Jeff's Avatar
Bugman Jeff
I seem to recall later cars having an extra rubber block on the inner fender lip to prevent just that. Maybe add some of those?
Old Aug 31, 2011 | 10:46 PM
blckslvr79's Avatar
blckslvr79
Worked for me.
Old Sep 1, 2011 | 08:08 AM
Roco71's Avatar
Roco71
you can find them from most supporting vendors.
Old Sep 1, 2011 | 08:27 AM
fzfox's Avatar
fzfox
Navigator
Default Sagging Hood
Thanks, I'll ck that from later year cars...
Old Sep 1, 2011 | 09:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Was your hood sagging before you did the work?
Old Sep 1, 2011 | 10:28 PM
fzfox's Avatar
fzfox
Navigator
Yes it was. Kept the hood because it is original to the car. I used some homemade rubber blocks to complete the bodywork assuming I could find someone who had the same problem and could could say- buy blocks for this year and type car...they worked for me. Iwill eventually find something. I know alot of these years the hood eventually sagged so...Thanks
Old Sep 2, 2011 | 11:53 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
use the hood alignment bumpers from vendors the 79 glue right onto the fender rail. cut off as much as you need find the best spots then glue in place.
Old Sep 2, 2011 | 06:36 PM
fzfox's Avatar
fzfox
Navigator
Thanks Vette Head! I'll ck it out. Lonnie
To sagging hood
