1970 LT-1 rescue
Old Sep 11, 2011 | 03:39 AM
Crafty12's Avatar
Crafty12
Default 1970 LT-1 rescue
Ok, so I'm now a 2 Vette owner. I had a thread going about how to spot an original LT-1, and with your help I made this purchase.
It is an LT-1. The block has the correct codes, and the serial number on the pad match the car. After that not a whole lot of LT-1 left, but its a good start I think. The exhaust and intake manifolds are gone. The TI ignition is gone. The AIR is gone. It has a Holly, but I am not sure if its the original or if its correct. Ill check the numbers tomorrow when I see it again. It doesnt run, but thats mostly because Bubba crossed some of the plug wires a couple of years ago, couldnt figure out how to fix it, and walked away. It has been sitting for 14 months, and the carb is all full of gunk. 45K miles. It needs some work for sure, but I dont think anything is too far gone. As per the rules, here are a few pics. More in my garage.
Old Sep 11, 2011 | 04:26 AM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
Nice project.
Have fun with it.
Old Sep 11, 2011 | 07:06 AM
1996Z15's Avatar
1996Z15
Nice purchase; I especially like the vintage wheels. I beleive that are Motor Wheel Spyders.
Old Sep 11, 2011 | 07:59 AM
stingr4y's Avatar
stingr4y
Good times!
Looks good in your garage.
Old Sep 11, 2011 | 08:51 AM
Alan 71's Avatar
Alan 71
Hi C12,
Looks like you've made a very nice discovery. The 70 LT-! certainly is a terrific car.
You may want to contact Drew Papsun, (keeper of all things related to LT-! data), with your VIN and other info. You may have a car not in his survey yet, or he may be able to tell you a little about your car's history.
Good Luck!
Regards,
Alan
Old Sep 11, 2011 | 09:05 AM
UberLegend's Avatar
UberLegend
Worthy project. The LT1 at WOT sounds amazing.
This air cleaner might be of interest to you. I like helping people spend their money.
http://cgi.ebay.com/ebaymotors/Origi...item3a6a289189
Old Sep 11, 2011 | 09:31 AM
Tim H's Avatar
Tim H
Those wheel to the right person will get alot of your money back!!!
Old Sep 11, 2011 | 09:48 AM
parkerracing's Avatar
parkerracing
Except that the center caps are probably worth as much as the wheels...lol.
Old Sep 11, 2011 | 10:15 AM
garage-ghost's Avatar
garage-ghost
NOT a Corvette LT-1 air cleaner.
Old Sep 11, 2011 | 10:17 AM
garage-ghost
You know we're going to need more pictures.
Old Sep 11, 2011 | 10:08 PM
Muddywaters's Avatar
Muddywaters
Luv to see the engine Matt! Nice find...very worthy project! Take your time....and do her justice! Muddy
Glad I (we) were able to help you with numbers, tell tales, ect.!!
Old Sep 11, 2011 | 11:33 PM
LT1driver's Avatar
LT1driver
very nice looking car and shouldn't take much to put back since motor there, how about trans and differential. First however is to get rid of none original side pipes and those ugly azz wheels. what was bubba thinking
Old Sep 12, 2011 | 12:29 AM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Old Sep 12, 2011 | 01:16 AM
UberLegend's Avatar
UberLegend
I KNOW......but it's cool.......and will cost alot of $$$$$$
Rated for 370 hp use......was good enough for Yenko.............
Old Sep 12, 2011 | 09:50 AM
Crafty12's Avatar
Crafty12
Thanks for the replys guys. I actually have the stock air cleaner and cover. One of the few stock parts that were still around. I tried to get it running yesterday, but I am not getting any fuel to the carb. When I looked at the car 10 days ago we had fuel coming up no prob, but now nothing. My fuel filter is in a clear plastic case, and that is not filling with fuel either. My guess is that there is debris in the line, but more likely the fuel pump gave up the ghost.
I am going to drain the tank next week and do a vacuum test on the pump, and make sure the lines are clear. Any other suggestions? Also what should / can I do with the old gas?
Old Sep 13, 2011 | 09:11 AM
bop's Avatar
bop
Back in the day their was more of those side pipes being run than the ones that GM put on the cars from the factory. You have a great start to a great car.
Old Sep 13, 2011 | 09:14 AM
oldsarge's Avatar
oldsarge
Great find, that is a project to be proud of, good luck and keep us posted.
To 1970 LT-1 rescue
Old Sep 13, 2011 | 10:35 AM
bop's Avatar
bop
Alan how do you contact Drew I would like to give him my vin number.
Old Sep 13, 2011 | 11:20 AM
ipmtim's Avatar
ipmtim
Cruise-In VIII Veteran
St. Jude Donor '06
Crafty, nice find.
Tim
Old Sep 13, 2011 | 12:35 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Originally Posted by Alan 71
Hi C12,
Good Luck!
Regards,
Alan
Drew is a member here on the forum you can pm him here http://forums.corvetteforum.com/memb...ew-papsun.html
Thanks for rescuing another LT1
Regards
Roy
