Stingray side emblum
Old Sep 14, 2011 | 08:10 PM
relic1864's Avatar
relic1864
Default Stingray side emblum
The stingray right side emblum had been loose for a while and recently it fell off and I lost it. I ordered a new one which will be here Friday. How do these things go on and how do i get it to stay on?
Old Sep 14, 2011 | 08:12 PM
GD70's Avatar
GD70
What year? Are there holes in the fender? Earlier ones used speed nuts. Later they had adhesive backing.
Old Sep 14, 2011 | 08:15 PM
relic1864's Avatar
relic1864
Its a 76. And yes there are 3 small holes in the finder
Old Sep 14, 2011 | 08:16 PM
GD70's Avatar
GD70
Then speed nuts it is!
Old Sep 14, 2011 | 08:19 PM
relic1864's Avatar
relic1864
how do I get to the back side to put the speed nuts on.
Old Sep 14, 2011 | 08:21 PM
Tom73's Avatar
Tom73
Thought that they had adhesive tape on the back and the pins/holes were just for alignment.
Tom...
Old Sep 14, 2011 | 08:30 PM
GD70's Avatar
GD70
If you have A/C, Power brakes, you will probably have to get to them from underneath. Remove the sort of triangular shaped splash shield behind the front tire between the body & frame. Then you can reach up.
I just checked two catalogs and 76 should not have holes. The script was held on with adhesive backing. 69-73 has the studs. A PO must have drilled the holes I'm guessing.
Old Sep 14, 2011 | 08:32 PM
relic1864's Avatar
relic1864
thanks
Old Sep 14, 2011 | 08:34 PM
Bronze76's Avatar
Bronze76
Tom...
That is how the emblems on my '76 are installed as well. I couldn't figure out an easy way to get to the pins so I just rely on the tape to hold the emblem in place.
Old Sep 14, 2011 | 08:48 PM
GD70's Avatar
GD70
Tom...
You are correct. I just checked my 70 AIM and it says to remove paper backing and apply a 10 pound load for 15 seconds. The pins are for alignment. There's a revision note nut removed dated 12/23/69.
Old Sep 14, 2011 | 09:43 PM
Willytrash's Avatar
Willytrash
My 74 has no speed nuts. Just alignment holes and double sided tape. I reapplied them with a little silicone sealant in the alignment holes and they've been on for years.
Old Sep 14, 2011 | 10:38 PM
7T1vette's Avatar
7T1vette
Well, the '71 had speed nuts and it kept the script in place. The adhesive was an overall cost reduction when including the cost of installation on the line. I do think it's a good idea to put some double-sided tape or [mild] contact adhesive on the backside of the script, just so it won't vibrate and rub through the paint over time. So, when I refurbed mine, I applied both methods.
Old Sep 14, 2011 | 10:39 PM
imariver's Avatar
imariver
After removing them for a paint job, I found that the adheasive on the back was not strong enough to hold them on again. I ran an 8-32 die over the pins and secured the emblems with 8-32 nylon insert locknuts.
Steve
Old Sep 15, 2011 | 08:38 AM
69 Chevy's Avatar
69 Chevy
imariver, speed nuts would have cut their own threads.
Old Sep 15, 2011 | 10:13 AM
imariver's Avatar
imariver
Well, let's just say I like to do things a little different. The pins on the C. O. R. V. E. T. T. E. letters on the back, were worn out and the speed nuts would not bite anymore. Did the same thing here, except that I used a 6-32 die cut new threads, used locknuts and now everything is nice and tight.
Old Sep 15, 2011 | 10:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...How do these things go on and how do i get it to stay on?...
emblem tape.
The assembly instruction manual (AIM) shows how they were installed at St. Louis.
If you do not have an AIM, you're gonna want one. All the aftermarket providers carry the AIMs. Do you have an owner's manual for your car? Lots of valuable information in the owner's manual.
Old Sep 15, 2011 | 12:32 PM
jcloving's Avatar
jcloving
The rear most pin can be reached thru the fresh air vent on the pass. side. My '76 has pins but no speed nuts. When I replace I will probably use the nuts.
Old Sep 15, 2011 | 03:22 PM
lvmyvt76's Avatar
lvmyvt76
No nuts are needed if installed correctly, the tape will hold them for years, mine are 35 years old and are still holding. Now there are some cheaper emblems out there so don't buy them, pay a little better for the real GM.
Old Sep 15, 2011 | 03:31 PM
7T1vette's Avatar
7T1vette
And, the "real GM" meaning that it displays the letters 'GM' on the box???
To Stingray side emblum
