C3's with 18" wheels only thread
Old 12-11-2011, 06:09 PM
  #101
flyeri
flyeri's Avatar
Courious. How far have you driven the car since you put them on? I don't think letting it sit to settle will do anything. What was the distance from center of the hub to the fender well before you changed tires. That measurement should be the same regardless of the wheel/tire size unless you change something in the springs or other suspension members.
Old 12-11-2011, 10:16 PM
  #102
tayful86
tayful86's Avatar
I haven't driven it at all. Its undergoing a new custom interior And full dash so at the moment it's not drivable. And the tires and wheels are actually the same height as the tires and wheels I took off it. Just a larger rim and lower profile tire.
Old 12-11-2011, 10:51 PM
  #103
flyeri
flyeri's Avatar
Mine is in the same condition. New wheels and tires, and the interior is out. You need to drive it to make the suspension settle back down.
Old 12-12-2011, 03:06 PM
  #104
blckslvr79
blckslvr79's Avatar
Then your gap should be the same as with the old wheels.
You need to roll your car forward and back a few times to allow the rear suspensions to relax. 8 or 10 feet each way should do it.
If that doesn't fix the gap, you'll need to adjust your rear spring bolts. Do your research here though before you try to remove them so you don't lose a limb.
Old 12-12-2011, 09:15 PM
  #105
73ls1
73ls1's Avatar
I have Boss 338's 18 x8 with 41/2 backspacing.The tires are Nitto 555 245/40/18.I think the tires are to small and the 40 sidewall is to short .Next summer I think I will buy 255/45/18.
Old 12-27-2011, 07:45 AM
  #106
det2orl
det2orl's Avatar
Finally got a pic since my wheels and tires were installed
Old 01-05-2012, 12:18 PM
  #107
rzkas
rzkas's Avatar
i like your ride and i also want to know what you did to the suspension. I like the way it sit and no gap. how did u lower the front and rear? What parts did you use? How is the bottom and road clearance. Nice car. Is there any tiee rubbing
Originally Posted by Rebelrob
Here a some 18's also.
Front 18X8 Rear 18X9.5
[IMG][/IMG]
Old 01-19-2012, 02:53 PM
  #108
rbat
Support Corvetteforum!
rbat's Avatar
Default I agree and would like to know too
Old 01-19-2012, 03:53 PM
  #109
jesse10886
jesse10886's Avatar
this is an awesome thread i want to go either 17 or 18 on my 79
the two sets of rims i love are the z06 rims like chevymans77 has or the torque thrust wheels that i see on allot of the c3 in my opinion those look the best on all later c3s they are just beautiful
i have 255/60/15 on the front now and 295/50/15s on the rear but they are worn out an i can't find these same tires sizes anywhere they were on it when i bought it i have no clue where the po found them but i want to go a different route
if i go with 18s what kind of change should i expect to feel comfort or harsh drive wise is it gonna make the already stiff an ruff ride even tighter and more aggressive on crappy paved roads or does it help the feel or does it stay the same pretty much?
Old 01-23-2012, 07:22 PM
  #110
Bee Jay
Bee Jay's Avatar
C5 Z06 replicas
18x9.5" front with 285/35-18 tires
18x10.5" rear with 295/35-18 tires, 6" backspace.
Offset trailing arms, modified rear sway bars and notched frame.
Search under Bee Jay for tech threads on the above mods.
Bee Jay
amandico82 (03-02-2021)
Old 01-23-2012, 07:36 PM
  #111
Red73
Red73's Avatar
The following 4 users liked this post by Red73:
73sbvert (10-02-2020), amandico82 (03-02-2021), Brink_71 (02-29-2024), CB-24 (05-19-2020)
Old 01-23-2012, 10:37 PM
  #112
gdh
gdh's Avatar
Originally Posted by Red73
stunning! is that a factory red?
Old 01-25-2012, 10:11 PM
  #113
TROPIC_THUNDER
TROPIC_THUNDER's Avatar
Looks like 96 C4 torch red.
Old 01-26-2012, 05:03 PM
  #114
toyvet1
toyvet1's Avatar
Old 01-26-2012, 08:17 PM
  #115
Red73
Red73's Avatar
It is!
Old 01-26-2012, 08:35 PM
  #116
palmbeachvette76
palmbeachvette76's Avatar
I didn't catch it in the other photo a few posts up but on this angle you can see how perfectly the tail lights work on this year since the lights aren't sunken and then compliment the paint color. Great choice in doing this mod
Old 04-12-2012, 10:22 AM
  #117
C3HOONIGAN
C3HOONIGAN's Avatar
What kind of wheel set-up are you running? Backspace, rim width, ect..
To C3's with 18" wheels only thread
Old 04-14-2012, 07:17 PM
  #118
vette427-sbc
vette427-sbc's Avatar
still waiting on the adapters to come in, so just a mock up for now...
285/35/18 front 285/40/18 rear
Old 04-14-2012, 08:20 PM
  #119
gdh
gdh's Avatar
Very nice, who makes those rims?
Old 04-14-2012, 08:29 PM
  #120
3JsVette
3JsVette's Avatar
Received 2,508 Likes on 1,657 Posts
Looks good! That's a lot of tire to fit under the stock fenders. What width wheels are you going with and how much backspace are you going to wind up with?
Quick Reply: C3's with 18" wheels only thread
