1970 clock
Old Oct 3, 2011 | 07:40 PM
sheldonbaker's Avatar
sheldonbaker
Default 1970 clock
hey clock not working pulled it out and cleaned it still not a thing think its junk lets have some 411 on it thanks
Old Oct 3, 2011 | 09:22 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Blew mine out with a little compressed air then shot it with some WD40. It started working in my hand as I walked back to the car.
Old Oct 3, 2011 | 09:42 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If it's toast you can have your movement replaced with a NOS or a quartz movement.
http://www.clockwks.com/The_Clock_Worx.html
Old Oct 3, 2011 | 10:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
The quartz movement is something that can be installed in a clock with very little hassle. It only takes about 30 minutes on the bench if you take your time. I'm seriously considering this as our next installation video.
As far as the original movement.. It is a Borg Clock and yes it is not a work of art... But it usually be fix by a novice with a little advice.
One of the leading failures in the original movement is the electro magnetic contact points. You'll find these under the wider arm. You can move this arm with your finger to open it up and inspect the contact points. If the contact points are burned or pitted you can use point file to make them smooth again.
I usually spray brake cleaner from a nozzle on the movement paying attention to keep it of the plastic inner frame (on later model cars it was plastic). The brake cleaner comes out of the bottle with some force so be careful. But it also dries very quickly! When you are finished cleaning the movement its very important to let it sit for a while so that all the cleaner evaporates. Compressed air works well but usually wont remove the old oil or debris from the movement. (If you do not allow the cleaner to evaporate before applying power to the clock you could ignite the movement and that wouldn't bring about a happy result).
I then use a lubricant I got from a friend of mine that is a jeweler that repairs watches. I have it in a tiny bottle and use a syringe for a tool to place the oil only where needed in the clock movement.
Before I ever install the clock back in the car or for that matter before I install it back in the can I make sure it cycles multiple times.
Sounds easy and in most cases it will work.. but there are times when it fails! You must also keep in mind that even after you repair the clock it can still fail...
Quartz Click Kit:
http://willcoxcorvette.com/product_i...oducts_id=2855
And just a note.. this kit comes with a link for a installation video.
Or you can send it in to me and I'll quartz convert it....
09750CONV 1968-1982 Clock Conversion Service, Quartz Movement. 68-82 $130.00
Willcox
Old Oct 3, 2011 | 11:10 PM
7T1vette's Avatar
7T1vette
If you really like to 'tinker' with stuff to make things work, fixing the original clock is about as good as it gets. But, if not, the quartz movement is the way to go....at least, it is if you want reliable, accurate time!
The original clock is an electro-mechanical movement which has a normal balance wheel type mechanism...but it is powered by a spring which is wound via a "pulsed" electrical solenoid. Every two minutes [approximately], a set of contacts on the winding mechanism come together and send electrical power to a solenoid which rewinds a 2-3 minute spring. It's really a pretty neat mechanism. This gizmo even has a time-correction system built into it that corrects for running too fast or slow, whenever an adjustment is made to the clock. If done properly, the clocks can be pretty accurate. Unfortunately, those contacts in the winding mechanism are the "weak link" in the system. After years of those contacts coming together every 2 minutes, the contact support fails from metal fatigue so that the clock will no longer rewind.
But, if you like to tinker, you can investigate; and if that's the problem, you might be able to silver solder or braze that metal piece to repair it. Or, the internal mechanism might just need a good cleaning (no dishwasher duty for a clock mechanism, however ). Just some light spraying with a compressed air/gas bottle and/or some careful cleaning of pivot spindles...or just take it to a local jeweler for check out and cleaning. Be VERY careful with the balance wheel and spring...they are delicate.
If any of that "trips your trigger", go for it!! If not....go quartz.
Old Oct 4, 2011 | 10:05 PM
sheldonbaker
tell you what i have got alot of info from this web page thanks to all i have fixed all my gauges from guys one here all lights and gauges work in my car and a lot of guys cars all that stuff does not work i just want to say thanks
Old Oct 4, 2011 | 11:00 PM
0Willcox Corvette
Former Vendor
Sheldon... That is exactly what makes this forum work well for everyone! Down the line it may be you answering the questions from your experience in fixing your own car.
Willcox
Old Oct 5, 2011 | 04:41 PM
champs65's Avatar
champs65
Glad the OP learned how to get his gauges up and running.
Old Oct 7, 2011 | 03:55 AM
7T1vette's Avatar
7T1vette
One good azz deserves another, I guess... Can't blame the kid for being pizzed. No one seems to have any trouble translating some threads from foreign countries.
Old Oct 7, 2011 | 10:59 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
The next time I have to clean out a thread like this because it goes off topic or for someone creating a hostile environment in the thread, the forum member responsible will have a LONG vacation from the forum. Not a threat... A PROMISE.
To 1970 clock
