69 wiper actuator - help
Old Oct 4, 2011 | 04:12 PM
69VetteFla's Avatar
69VetteFla
Default 69 wiper actuator - help
Has anyone replaced their wiper actuator and know of someone who sells a non-chinese one or at least one that works?
Old Oct 4, 2011 | 04:55 PM
...Roger...'s Avatar
...Roger...
Whats yours doing,a seal usually fixes them ?
Old Oct 4, 2011 | 05:03 PM
69VetteFla's Avatar
69VetteFla
This is what is frustrating about being a new guy and not knowing my way around the car. Have the car at who I have been told my multiple people is one of the best vette guys in South Fla, and he is telling me that it is leaking and not repairable.
Old Oct 4, 2011 | 05:09 PM
...Roger...
Do you think he is referring to the actuator and not the relay ? Its possible the actuator (can) has a ruptured diaphragm but if the diaphragm is good it should be repairable.
Old Oct 4, 2011 | 05:15 PM
69VetteFla's Avatar
69VetteFla
When I shut the car off sometimes the wiper door would lift. I find that the vette mechanics down here have pretty bad attitudes so best not to ask too many questions until you get your car back otherwise it costs more and they will keep it for longer. My sense of the guy is that what I heard about him is right and that he knows what he is doing so am going to assume that he is right. He did say that the chinese junk that he sees leak a lot so he wanted to put a later year actuator on and I told him that since the car is original, if I have to replace it I at least want it to look the same as the original. Now I am in the position of hoping that the replacement which he warned are chinese and junk doesn't leak.
Old Oct 4, 2011 | 06:52 PM
Alan 71's Avatar
Alan 71
Hi VF69,
From the problem you described I have to agree with Roger that this may be a relay malfunction.
Remember, the the actuators only drive the wiper door or headlight doos open or closed.
Problems that occur when the car is started or shut off OFTEN are relay problems.
Regards,
Alan
Old Oct 4, 2011 | 07:05 PM
69VetteFla's Avatar
69VetteFla
Originally Posted by Alan 71
Hi VF69,
Regards,
Alan
I am going to mention that to him tomorrow and will let you guys know where it goes.
Old Oct 4, 2011 | 09:42 PM
BBCorv70's Avatar
BBCorv70
The reference to changing to the newer type suggests this is indeed the actuator. I believe the vacuum relays are the same for 69 or later.
If it's the actuator, I'd think it may be a seal. I'm not familiar with the 68/early 69 can so I can't say from any personal experience if the seals are the same as the later years.
I think a ruptured diaphram would likely cause problems going up or down, don't know why it would only cause a problem when the motor is shut off.
For the wiper door to lift, there must be some residual vacuum getting to the backside of the actuator after the car is turned off. Sounds like it may be a vacuum relay or maybe another leak somewhere.
Old Oct 4, 2011 | 09:50 PM
69VetteFla's Avatar
69VetteFla
Thanks BB. The car is a later 69 and he did say that it is affecting more than just the wiper door going up when the motor is off. He is working on a few different things for me so I try to absorb as much as I can which is tough to do when you really are not familiar with this stuff. Don't really understand this part, but I thought he said something about it not being great for the motor or something to be driving with an actuator that is leaking. Like I said, not sure if this is exactly what he said, but would that make any sense? Confusing to me cause I thought the actuator and that whole vacuum set up are just mechanical things related to the headlights and the wipers and don't know how it would affect the motor or performance.
Old Oct 4, 2011 | 09:51 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Bad check valve will often exhibit this behavior.
Cheap and easy to check.
Pull it out and blow/suck through it both directions. It should only pass air one way.
Old Oct 4, 2011 | 09:53 PM
binster's Avatar
binster
I replaced mine in my 69. Heads up, there are two different types for that year
http://forums.corvetteforum.com/c3-t...-break-it.html
Old Oct 4, 2011 | 09:54 PM
69VetteFla's Avatar
69VetteFla
Thanks man - I figured that out and made sure that he knew that part which he did - I have the later year '69 one. Thanks
Old Oct 5, 2011 | 09:02 AM
builder's Avatar
builder
..... I find that the vette mechanics down here have pretty bad attitudes so best not to ask too many questions until you get your car back otherwise it costs more and they will keep it for longer. My sense of the guy is that what I heard about him is right and that he knows what he is doing so am going to assume that he is right. ..........
Maybe the "vette mechanics" have a bad attitude because they get confused easily. Maybe he is "right" because of an attitude problem that "can't" be corrected.
Why would they have bad attitudes if they are "right" about everything?
Old Oct 5, 2011 | 09:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Ding Ding Ding We have a winner.
Old Oct 5, 2011 | 09:23 AM
69VetteFla's Avatar
69VetteFla
Don't understand the question - are you implying that you can't have a bad attitude and be a good mechanic?
Old Oct 5, 2011 | 12:00 PM
builder's Avatar
builder
Not exactly. It was implied that all the vette mechanics there had bad attitudes, and that it would cost more and probably take longer if you quizzed them. I consider a good mechanic to have a little more than attitude...like morals and honesty.
Old Oct 5, 2011 | 12:11 PM
69VetteFla's Avatar
69VetteFla
My mechanic that I have been using for 10+ years down here for my other cars is what you are referring to and I wish that he had the old vette knowledge. My experience with the 4 vette mechanics down here that I have used so far is that they have a line of cars waiting to come in (many of them sitting at their shop collecting dust literally) and don't really want to be bothered with questions. 3 of them did don't know as much as many of the people on this forum. At this point I would like a mechanic who at least knows what they are doing and I will be satisfied - not happy, but satisfied. I agree though that a truly good mechanic should have morals and honesty and I think many do, just not any of the vette guys down here in South Fla
To 69 wiper actuator - help
Old Oct 5, 2011 | 02:06 PM
69VetteFla's Avatar
69VetteFla
Now he is saying that he also needs to replace the vacuum resorvoir? Feel like he is doing a lot of replacing. Didn't understand what he was talking about re: vacuum resorvoir.
Old Oct 5, 2011 | 02:29 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Default System Diagram
Here is the system diagram, showing all the parts and pieces. I am not sure what is different on the 69 forn the 70-72 diagram.
Old Oct 5, 2011 | 02:32 PM
69VetteFla's Avatar
69VetteFla
Thanks. What he said he is going to do is take the 80-82 vacuum reservoir and put that on the car which he said is mounted up front as opposed to on the driver side near the fender. Confused why he would do that.
