Nope my gas guage hasnt worked since I bought the car. Looks like I may have found the reason.
It also looks like my connecting tab on the sender unit is either broken off or not like the on in the picture
It has a tab in the general area of the one in the picture, but it doesnt have the 90 degree bend in it and looks shorter.
With a strong enough soldering iron, you can solder a wire pigtail with a connector to the unit housing surface. Have done that several times and works well.
Using a soldering iron on a fuel tank (that has not been completely emptied) is not 'advisable'. You can connect that ground to any point on the tank or on the car's frame. To check it out first, just run a jumper wire from that loose connector to a grounding point and see if the fuel gauge works (key must be in "ON" or "ACC" position).
