Support rod on Headlight assembly question
Old Oct 15, 2011 | 10:51 AM
TWINRAY's Avatar
TWINRAY
Default Support rod on Headlight assembly question
Here are my original headlight assembly supports. On the passenger side, besides having an inner and outer rod, there is another rod that extends downward. There is no such rod on the driver side. Looking through supplier catalogs and the Assembly manual, I can't find that there was this "downward" rod. Am I just missing this additional rod on one side and they are unobtainable?
Old Oct 15, 2011 | 10:58 AM
spdrcr29's Avatar
spdrcr29
What year is your vette? Neither my 71 or 72 have that rod you are asking about. Not really sure why it is there...
Old Oct 15, 2011 | 11:00 AM
TWINRAY's Avatar
TWINRAY
Hi,
Year is 1969. I think the assembly date was in March 1969.
Not sure what it was attached to. Car is now in process of being put back together.
Old Oct 15, 2011 | 11:07 AM
spdrcr29's Avatar
spdrcr29
If i'm not mistaken, it actually looks like a rear bumper bracket...
Old Oct 15, 2011 | 11:11 AM
GD70's Avatar
GD70
Shouldn't be there. My guess is the assembly was sagging and the PO used it as a support to push it, hold it up.
Old Oct 15, 2011 | 11:17 AM
TWINRAY's Avatar
TWINRAY
Thanks both for your replies. It may be a "Bubba" from one of the 2 PO's. I bought the car in 1973 and after taking out the supports see that one ear is broken off and a pop-rivet repair is on another ear so looks like it was probably tapped. I will match up with a rear fender bracket and see if it is the same. If so, it was probably "added" like said for additional support. Will update and thanks
ps. you can see the pop rivet repair on the side with the additional rod and the broken ear is on the same side front.
Old Oct 15, 2011 | 12:47 PM
70BBvert's Avatar
70BBvert
That's what I'm thinking too
Jim
Old Oct 16, 2011 | 11:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If it is not shown in your AIM, it was not installed on the assembly line.
I agree: looks like a rear bumper bracket. Hang on to it.
To Support rod on Headlight assembly question
