question about electrical
Old Oct 15, 2011 | 09:36 PM
cgbrown39114's Avatar
cgbrown39114
2nd Gear
Default question about electrical
New to forum. I just bought a 69, the tail lights and back up lights, back side marker lights not working-any suggestions about where to start. Brake lights are working.
Have power on both sides of leg at fuse box. any suggestions?
Old Oct 15, 2011 | 09:50 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i would certainly check to make certain the taillamp bulbs are the correct ones. then i would check to see if you are getting power to the appropriate sides of the bulb sockets. they are all obviously tied togegher and i would also check the ground to that circuit that is the most common electrical problem you will face with a C3
welcome to the forum
Old Oct 16, 2011 | 10:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Fuses.
Old Oct 16, 2011 | 11:03 AM
Alan 71's Avatar
Alan 71
Hi cgb,
WELCOME!!!!
New member and new old 69. MUST have a couple of pictures so we can enjoy your 69 too!
Since you checked for power at the fuse; have you checked for power at the sockets?
Regards,
Alan
Old Oct 16, 2011 | 02:39 PM
myoriginal77's Avatar
myoriginal77
You'd be surprised what crazy things the wrong bulb jammed into the socket can do
Frank
Old Oct 16, 2011 | 05:57 PM
Rally68's Avatar
Rally68
My 1968 has a single ground wire for the rear lights, it connects to the driver's side frame at the same place as the antenna ground strap. I don't know if that's the stock location. A test light and some jumpers with alligator clips will help you figure it out
Old Oct 16, 2011 | 06:44 PM
joewill's Avatar
joewill
if the brake lights work it is not the ground wire.
also theres a connector down by your foot dimmer switch that connects your entire rear harness to the front under dash harness. Check for power there ( the brown wire i think)and make sure the connection is good.
this is also assuming that you have dash lights and front running lights, and your turn signals work?
Old Oct 16, 2011 | 07:19 PM
cgbrown39114
2nd Gear
Thanks a lot-will go and check that out.
To question about electrical
