68 steering rag joint ( again ! ).
Old Oct 16, 2011 | 04:03 PM
WESCH's Avatar
WESCH
Default 68 steering rag joint ( again ! ).
Hi
Yes, I know, many threads already about this, but I'm still lost .
The GM 68 rag joint P/N 7806391 is not available anymore, is it ?
Is the Ecklers rag joint P/N 23023 OK ? Doesn't6 look complete to me.
http://www.ecklerscorvette.com/corve...1969early.html
And yes, it is for a non PS , hence manual steering 68.
Again sorry for the question after so many threads in the file already.
Rgds. Günther
Old Oct 16, 2011 | 04:42 PM
Mike Ward's Avatar
Mike Ward
That's only half of the joint. Here's what you want
http://shop.corvettecentral.com/C2-1...-p9380067.html
Why not just repair the joint you already have?
http://shop.corvettecentral.com/C2-1...-p7102934.html
Old Oct 17, 2011 | 01:39 PM
WESCH's Avatar
WESCH
Hi
Thanks a lot.
Guess that is really what I want:
Correct, complete upper and lower.
Corvette Central #: 562201
Original GM #: 7806391
Car years: 1967, 1968, 1969
I will probably order the assy and the kit. I remember that Jim mentioned that the repair kit is not OK as is due to no shouldered bolts and possibly weak rack joint ( not enough layers or so ).
But for the price I can try it and junk it if I don't like it.
Thanks & rgds. Günther
Old Oct 17, 2011 | 03:22 PM
MrJlr's Avatar
MrJlr
Originally Posted by WESCH
Hi
Thanks a lot.
I'd listen to Jim on this one.......seriously.
Old Oct 18, 2011 | 12:24 AM
aussiejohn's Avatar
aussiejohn
Default Borgeson.com
WESCH,
Order part # 000941 from www.borgeson.com, it has the correct shouldered bolts and the correct composition rag joint. You have to re-use your front and rear steel flanges if they're in good condition.
Regards from Down Under.
aussiejohn
Old Oct 18, 2011 | 05:42 AM
Carlos840's Avatar
Carlos840
Jim shea recommended this guy to me, he has all the steering parts you could dream of and is a real nice guy!
http://www.corvettesteering.com/
I got an OEM steering coupler from him!
Old Oct 18, 2011 | 10:04 AM
7T1vette's Avatar
7T1vette
Just remove what you now have, take digital photos of it for later reference, disassemble it and throw all but the rubber flex-disc in some carb cleaner for a day or two. Order a new flex-disc from a vendor and rebuild the one you have. If the new flex-disk does not have any 'grounding' wire mesh imbedded in it, run a piece of braided copper grounding strap from one side to the other. Done deal....
P.S. Take note that the two bolts/nuts are different. Put them back in the same orientation that you removed them.
Old Oct 18, 2011 | 10:11 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Rebuilt my gear and provided a new rag joint. Perfect.
Old Oct 18, 2011 | 12:11 PM
WESCH's Avatar
WESCH
Hello aussiejohn
Their pic on the Intranet does not show the shouldered bolts, but ordinary bolts threaded up to the bolt head ?
@ all.
Thanks a lot for the feedback.
I asked corvettesteering.com if they have a 68 joint assy.
Once I have a new assy, I will try to repair my old one.
It is not too bad, just starts to fold the rag a bit when steering during standstill. No PS, so all the wheel force is transmitted through he rag.
Brgds. Günther
Old Oct 21, 2011 | 01:52 PM
WESCH's Avatar
WESCH
Hi
I ordered from Corvettesteering.com.
Tom from there was very friendly, instant reply to my questions.
I am very confident that I will be pleased with his product.
1968 corvette Coupling heavy duty with ground $95.00
shipping priority mail $34
It appears that ZIP has the same or similar coupler, but a bit more expensive. A German colleague was happy with the 68 ZIP coupler.
Thanks for all help in making my decision.
Rgds. Günther
To 68 steering rag joint ( again ! ).
