Headlight assembly install question
Old Oct 19, 2011 | 01:50 PM
TWINRAY's Avatar
TWINRAY
Default Headlight assembly install question
I assume it would be better when installing a new hood surround (and new fenders, inner fenders) to have the assemblies in place but how difficult would it be to install the assemblies after the hood surround is already installed?
Old Oct 19, 2011 | 02:30 PM
Alan 71's Avatar
Alan 71
Hi tr,
I'd think just the opposite... I'd install the complete head light doors, with frame, after the surround/aprons are completed and then align them to the openings in the surround.
You can install the headlight doors without all the 'working parts' first to alghn them, and then install the mechanisms.
You'll have access through the grill openings, and from below through the cooling cut-outs.
Regards,
Alan
Old Oct 19, 2011 | 03:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
On your new front fiberlglass, is the lower valance panel already bonded in? If not, you have a world of room to work with headlight installation and adjustment.
Less room if the panel is installed.
Old Oct 20, 2011 | 08:26 AM
70BBvert's Avatar
70BBvert
Are you installing a one piece or assembled front clip? I installed the nose then dealt with the headlight assemblies after wards. It wasn't all that hard to get them in & out, especially with the hood off. Adjusting everything can be tedious, so remove the actuator and they can be opened & closed by hand pretty easily. Even with the springs in place.
Jim
Old Oct 20, 2011 | 01:27 PM
TWINRAY's Avatar
TWINRAY
Originally Posted by Alan 71
Hi tr,
Regards,
Alan
Good news - I (somehow) thought the opposite. Assemblies () will take 1-4 weeks for delivery so during that time, I can (hopefully) install the fiberglass pieces I've had since the summer of '08.
Thanks Alan, Fred
Old Oct 20, 2011 | 01:28 PM
TWINRAY's Avatar
TWINRAY
Nope, not yet, Thanks EM,
Fred
Old Oct 20, 2011 | 01:30 PM
TWINRAY's Avatar
TWINRAY
Jim
Hi Jim,
Neither. I have a PM top surround, inner fenders and fenders along with corresponding bonding strips.
Glad to hear I can do the assemblies after so maybe I can get the pieces on and bonded before the winter.
Regards, Fred
Old Oct 21, 2011 | 08:35 AM
70BBvert's Avatar
70BBvert
Hi Jim,
Regards, Fred
Then you may want to take Easy Mike's suggestion & leave the lower valence panel un bonded until you fit & adjust the headlight assemblies. Get everything fit and adjusted including the lower valence. I found with the repo inner fenders that I had to brace them against the tires to get them into the proper position. Otherwise they held the bottom of the fenders to far apart for the lower valence.
Also test fit your grilles, bumpers, brackets, etc before bonding anything. Basically put everything together to make sure it all fits, then take it apart again. Lost count how many times I went through that routine
Jim
Old Oct 21, 2011 | 02:30 PM
TWINRAY's Avatar
TWINRAY
Jim
I'm sure we'll be going over all of this when you come over and help me with the install .
On another note, what did you do about the rivets when you installed the inner fenders? The original rivets are 1/2" diameter and are "real" rivets and not pop rivets. Did you go "correct' with the real rivets and, if so, did you use the rivet setting tool - or did you do it with pop rivets
Fred
ps. did you use screws or clamps to hold the pieces together when bonding?
Old Oct 21, 2011 | 04:23 PM
70BBvert's Avatar
70BBvert
Fred
Did I mention I'm still working on finishing mine 10+ years later
I used original style soft aluminum rivets from Doc R along with a rivet set tool in my air hammer. Pretty easy to do, especially by myself. Set the air pressure down to about 30 - 35 psi. Otherwise it hits way to hard and the tool will bounce off the rivet.
You can back up the rivet head with a body dolly, hammer head, steel bar, etc
It's getting to the point in the year that it will be to cold to bond the nose on also. Unless you have a heated garage
Jim
Old Oct 22, 2011 | 11:16 AM
TWINRAY's Avatar
TWINRAY
It's getting to the point in the year that it will be to cold to bond the nose on also.Jim
Yea, I know
Old Oct 22, 2011 | 04:07 PM
Alan 71's Avatar
Alan 71
Hi TW,
Just my 2 cents.
Since you have the pm fiberglass pieces and bonding strips, it would be a shame to not use the flat headed aluminium rivets where they originally were. Even though they're more work.
The factory used 3 or 4 different lengths so there's not too much shaft (personally I've never had that problem) to mushroom.
Also, there are countersunk and oval head rivets used too. I can't remember just where, or even if, any were part of the front clip.
Good Luck!
Regards,
Alan
Old Oct 23, 2011 | 08:18 AM
70BBvert's Avatar
70BBvert
Yea, I know
By the way, I used a combination of screws & clamps. If you use screws plan on glassing in the holes to prevent the filled area showing through the paint.
Jim
Old Oct 23, 2011 | 01:43 PM
TWINRAY's Avatar
TWINRAY
Hi TW,
Just my 2 cents.
My thoughts exactly
Old Oct 23, 2011 | 01:45 PM
TWINRAY's Avatar
TWINRAY
Jim
I'd like to use just clamps (if that's possible) to eliminate the possiblity of the "holes" eventially showing thru
To Headlight assembly install question
