got lucky twice
Old Oct 22, 2011 | 12:06 PM
tomgallucci57's Avatar
tomgallucci57
Default got lucky twice
first,,a friend gave me some r 12 to take with me to the shop to see if i could my ac working.two hours later the shop says to me that your air is working fine,so i consider that a small miracle.just wanted to share that with all of you. secondly,i was looking thru e bay at other 68 vettes to compare prices,and found a picture of the rear compartment housing removed,the one behind the passenger seat,and low and behold theres the jack,,i never knew it was under the insert. so i go over to my 68,open the compartment door, pull out the insert,and bang,the jack,shinney black,no rust,but no jack handle.thats ok cuz i can get another.only problem now,is i see that the jack is cocked,sort of bent as it sits in its closed position.someone must of used once,or twice,its that clean,but unfortunatly put a slight twist in it.im just so glad to have found it,,thought id share the experence.oh ya,its dated 8A. talk to you later,tom in cleveland.
Old Oct 22, 2011 | 03:50 PM
Alan 71's Avatar
Alan 71
Hi Tom,
2 VICTORYS!!!!!
The DATED jack is a VERY nice find!!!!!
WELL DONE!
Regards,
Alan
Old Oct 23, 2011 | 10:06 AM
tomgallucci57
hi alan,always good to hear from you... tom
Old Oct 24, 2011 | 09:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by tomgallucci57
...theres the jack,,i never knew it was under the insert...
Read through your owner's manual.
Old Oct 24, 2011 | 11:43 AM
tomgallucci57
guess i know whats next on my list,,thanks mike
Old Oct 24, 2011 | 01:42 PM
Easy Mike's Avatar
Easy Mike
Lots of good stuff in the owner's manual. You could have found your jack years ago.
To got lucky twice
