Mini Starter Burned
Old Oct 23, 2011 | 08:07 PM
68vetteman's Avatar
68vetteman
Default Mini Starter Burned
Last week on our way to Ocean City MD, 125 miles from home, my 2 week old mini starter burned up when I stopped to get gas. I think the heat from the headers caused the solenoid to stick and the starter was turning with the key off. Talk about a sick feeling. By the time I cleared the luggage from the back to disconnect the battery it was too late. There was a garage next door with a starter and a mechanic. The starter manufacturer is sending a refund so the outcome isn't that bad. Next project REMOTE BATTERY DISCONNECT SWITCH !!
68 Vetteman
Old Oct 23, 2011 | 08:14 PM
rod7515's Avatar
rod7515
Just curious but do you have a heat shield around your starter? I use a standard starter and I also have headers. Your post gives me another reason to worry. I traveled to OC last weekend as well which is a 175 mile trip one way for me. Luckily I had no issues. I only take it on a trip like that once a year. Ive been also thinking about the starter heat wrap that summit sells just to keep heat away.
Where do you plan on putting your disconnect?
Rodney
Old Oct 23, 2011 | 08:26 PM
68vetteman's Avatar
68vetteman
Rodney
I don't have a heat shield around the starter. I never had a problem with the stock starter. We were on route 1 which was highway driving(not stop and go traffic). I think I just got a bad starter. I"m thinking of mounting it in back of the driver seat close to the battery.
68 Vetteman
Old Oct 23, 2011 | 09:13 PM
Gordonm's Avatar
Gordonm
I had one self destruct on a friends car I was doing the work on. It was only a few starts old and it stuck in and was spinning. The car shut off but it was on the alignment rack. We push started it and I got it home no problem. Here is what was left of it after I removed it. Replaced it with a GM mini starter and it is still going fine. Just a bad one
Old Oct 23, 2011 | 09:39 PM
68vetteman's Avatar
68vetteman
I don't know what my starter looked like but the wires and starter were smoking. I had to have the garage send it back for me.
68 Vetteman
Old Oct 24, 2011 | 04:54 AM
WESCH's Avatar
WESCH
Hi
Strange that a starter motor burn out with only 1 battery charge.
I had several unsuccessful starting attempts draining the battery with the starter when I worked on the car without any starter failures.
A battery is rather fast drained having a starter motor sucking the amps out.
Oh, the battery disconnect switch is mounted on the battery negative stud. Easily accessible by just grabbing with the right hand backwards.
I disconnect it whenever I stop the car, also for refueling.
Rgds. Günther
Old Oct 24, 2011 | 08:35 AM
KevinG's Avatar
KevinG
Had a mini-starter that was only a few starts old go bad. It was on a trailer and luckily it started before so I could load it up on my rental trailer.
I'm sticking with a standard starter from now on...
Old Oct 24, 2011 | 11:03 PM
68vetteman's Avatar
68vetteman
The shop next to the gas station is a "speed shop" and the only starter they had was another mini-starter. Hope this one is better.
68 Vetteman
Old Oct 25, 2011 | 02:26 AM
WESCH's Avatar
WESCH
Hi
I now remember that my 1st mini starter ( from Summit ) burned out on the first starting attempt, actually the solenoid burned up.
Summit replaced it instantly without any hesitation and the 2nd one is now OK for several years already. ( great customer service ).
So may be this mini starters ( at least the cheap units ) do have some flaws. But you can't beat the price. Could actually have a spare for what they are sold for.
Rgds. Günther
To Mini Starter Burned
