1975 Dash Interchange
Old Oct 24, 2011 | 12:27 PM
Rick Crunelle's Avatar
Rick Crunelle
Default 1975 Dash Interchange
OK, so I finally got my first Corvette. When I get around to taking a pic, I'll post it and officially introduce myself to the forum. It's a 1975 and is in pretty nice shape.
So my first question about this car... I need to replace the lower left dash (the part with the speedo and tach). I need the whole thing... bezel, gauges, vents and all. So what years will interchange? I think I was told the tach drive changed in 1975 from a cable to electronic, but I'm not sure.
Thanks!
Rick
Old Oct 24, 2011 | 12:29 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Thanks!
Rick
How about this one? Its from a 72, which is all identical from a 75, other than mentioned above the tach. No cracks breaks etc. Asking $200 plus $30 for shipping
Old Oct 24, 2011 | 12:52 PM
KevinG's Avatar
KevinG
^^^ great deal
Old Oct 24, 2011 | 01:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Looks like an electric tach to me.
Old Oct 24, 2011 | 01:44 PM
gbvette62's Avatar
gbvette62
The left dash pictured here is not from a 72, as stated.
The tach in that cluster is a 75-77 electric tach, not a 72 cable driven one. Also, 72 dash panels didn't have the small rectangular air vent, to the right of the column. The vent was only found on 74-77 dashes, and only in cars with air conditioning.
Because of the vent and tach installed in it, the dash appears to be either a 75-76 or 77 dash. There is a slight difference to the 77 dash, but I can't recall exactly what it is right now.
If the OP's 75 has air conditioning, this dash, as well as any other 74-76 dash panel will work for him. If he does not have air, then the left side panel from any non air, 71-76 Corvette will work. The 75-76 both use the same electronic tach, and while 77 also uses the same tach, the face is slightly different.
Old Oct 24, 2011 | 05:07 PM
Rick Crunelle
Thanks for the responses. My '75 has a/c so it looks like this dash/gauge combo might work. I'm not concerned if the face of the gauge is from a different year as long as the both work.
P/M sent to chstitans42.
Rick
Old Oct 24, 2011 | 11:24 PM
chstitans42
TheCorvetteBen
Well you learn something everyday. Im pretty good at telling what parts are from what years, but I guess I need to brush up on my chrome bumper details. Guess that is what happens when you dont have your own to work on
Old Oct 24, 2011 | 11:26 PM
chstitans42
TheCorvetteBen
To answer your question, the 77 dash differs only in the far right side, where it meets the center guage bezel. Since it was converted from a pot metal housing to the plastic one, that edge is different. instead of resting along side, it actually covers that edge a little. take a look:
To 1975 Dash Interchange
