pls i need ideas, guide, steps on how to adjust or align or make my hood fit good. is this hood a keeper or i should start looking for another? i have added pics for you to see what dealing with. Help pls. the car is a 82 coz it has a 82 type front nose that has a removable front bumper.
An actual 82 VIN will be 1G1AY8786C51xxxxx withe the xx's standing for the consecutive unit number. The ninth character is a check digit and will vary with each car.
On the driver's hinge post, you should find a stainless steel trim tag. It will show the time/build date and the factory codes for paint and interior color. Jot down the information on the tag or take a picture of it.
Here's what you're looking for. This one is from an 81. Your tag will be similar.
thanks for your post. here is the info i got from the card. left side door jam plate info (upside down T) T81 T3L T3U 3PM E, C08A120958 and vin is 1G1AY8788C51209XX
is this vin a collector corvett or special edition collector's corvette?
pls i need all help to figure out this hood issue and fix my hood and car.
First you need to adjust the hood slightly over the the driverside, that will center it. then you mark your hinges to the hood with a marker or crayola. Now adjust nose to windshield evenly ever so slightly. Make sure you have the hood hinge bolts just a little bit loose where it takes some effort to wiggle it where you want it. Since the fact that its not an 1982 hood, it will never be a perfect fit. If you want a perfect fit, find a hood in the same year as yours. Its all about what you want though.
all i want is a hood that fit good and have clearance for edelbrock carb with round air filter. Is the 79 hood better than a 82 hood. On the hood i saw a faint marker writing that says 75. Is this hood a keeper? If yes i will only invest ln a hood scope.
So my nose need alignment also?
You plan to put a scoop on it anyway then just use the hood you have,
That is the same hood that is on my modded 69 at the moment and it clears an edelbrock intake and round air cleaner....
Your hood needs to move to the left a little (driver's side). The point of the hood will line up with the V in the surround panel. You want the fender to hood gap on each side to be the same.
You can purchase rubber blocks to raise the outer edges of the hood to meet the fender line. Placement of the blocks in the rain gutter on the fender is trial and error. Move them around until you get a match.
You have two areas on the hood which look like they need fiberglass repair.
