Engine VIN pad question....
Old Oct 31, 2011 | 12:17 AM
U5512's Avatar
U5512
Default Engine VIN pad question....
Newbie here!!!
If I were to look at the engine VIN pad to verify the partial VIN number, would I be able to see the pad and read it even with the AC compressor and smog pump (I think - sitting on top of water pump?) in place? Below is a borrowed picture (from forum member dslater35) of a '75 Vette engine compartment, which seems to be very crowded and tight with everything in place. What would you do in this case to verify the number on the VIN pad? Thanks in advance!!!
Old Oct 31, 2011 | 12:52 AM
Mike Ward's Avatar
Mike Ward
Yes, the pad is almost visible in the pic. Almost.
Old Oct 31, 2011 | 03:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You'll probably want a flashlight. It helps. Remember: there are two numbers stamped on the pad. You will want to jot down both.
Old Nov 1, 2011 | 04:02 AM
hunt4cleanair's Avatar
hunt4cleanair
Yeah...for this one you'll need all the high-tech tools. Flashlight, mirror and even a broach buster might help.
To Engine VIN pad question....
