windshield removal
Old Oct 31, 2011 | 02:33 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Default windshield removal
What is the best way to get a windshield out? tools?
Old Oct 31, 2011 | 02:44 PM
rogman16's Avatar
rogman16
Sure there is a fancy tool nowadays, but remember using a piece of electric fence wire to cut the bead all the way around... It helps to have a helper for the lower middle windshield, but the rest can be done be one person...
Let me know how you do it, as I will be taking mine out in a few weeks...
Rogman
Old Oct 31, 2011 | 03:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by chstitans42
...What is the best way to get a windshield out? tools?...
Honest answer: farm this job out to the pros. They'll have the job done in a third of the time it would take you or me and will guarantee their work to boot. Out with the old, in with the new in no time.
Old Oct 31, 2011 | 03:31 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
In the past I've used Guitar string, the big metal one that strums the low notes (the extent of my guitar knowledge). Wrap one end around a dowel or similar and poke the other end through a part of the windshield that has the most clearence to the body. Grab that end and wrap around another dowel.
Now you have a saw of sorts. Carefully saw back and forth as you work your way around the glass.
An even easier way is to have Safelight come out. They will replace the whole thing with a warrenteed unit for under $300 You might be able to work a deal for them to just come out and remove only.
Old Oct 31, 2011 | 06:22 PM
Alan 71's Avatar
Alan 71
Hi 42,
If it's the original glass you need to be VERY careful! The old glass has gotten very brittle.
On my 71 I'd cut it loose and it cracked lifting it out!
Good Luck!
Regards,
Alan
Old Oct 31, 2011 | 06:25 PM
tjhphoto's Avatar
tjhphoto
I spent two days very carefully taking mine out just find out that it wasn't an original with a date. Need to buy a new one after all. check yours for a date.
Old Oct 31, 2011 | 06:46 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
very difficult to remove without breaking.
( had mine about 80% out, then you hear the dreaded, (Crack!)
try removing yourself, ....you will need time to do cleanup/repair work.
Glass installer won't want to wait for you.
do your clean/repair, then have a pro Install replacement. or old if your lucky.
Old Oct 31, 2011 | 06:53 PM
Clubby99's Avatar
Clubby99
If replacing, an easy one man job. Cut around the bead an pull out. If reinstalling, then be very careful or the glass will crack.
Took me about 30 minutes. As other posters stated, you will need to clean up and likely repaint. That took hours. Then have the glass guy install.
Old Oct 31, 2011 | 07:25 PM
Alan 71's Avatar
Alan 71
Hi,
What are the chances of getting the professional installer to 'dry-fit the glass?
Unless he does that, the chances of the ss pillar and header trim fitting nice and flush are slim at best.
Regards,
Alan
Old Oct 31, 2011 | 11:13 PM
1-2-b-67L89's Avatar
1-2-b-67L89
Originally Posted by Alan 71
Hi 42,
Good Luck!
Regards,
Alan
Alan, what windshield did you end up going with. Believe I learned recently the what was the most correct is now out of business? Made in Mexico now? We believe our windshield (replaced) does not have the correct form which causes the wiper cover to not fit properly, i.e. hits the glass toward the middle. Or its not installed correctly????
Chick
Old Oct 31, 2011 | 11:33 PM
chstitans42
TheCorvetteBen
I just want it removed from one of my parts cars, not looking to reinstall just yet. I tried the guitar string meathod on the back window, and went through three of them... I was just wondering if there was a special tool
Old Oct 31, 2011 | 11:43 PM
milo30's Avatar
milo30
I bought the tool at the parts store but it was still too difficult to use and I wasn't reusing the glass anyway so I got out a big hammer and shattered it then pulled it out. No need to go to trouble if it is trash anyway. Just put a tarp down in interior. Good chance of it shattering anyway when you try to remove it with the tool if it is old and brittle.
Old Nov 1, 2011 | 01:18 AM
Clubby99's Avatar
Clubby99
Big long knife will work.
Old Nov 1, 2011 | 06:46 AM
Rayzzz's Avatar
Rayzzz
Use a spay bottle with a little dish soap in it. Spray the soap and water around the area your working in to cool and lube the wire so it will cut easier and the wire will not brake as easy. Two small blocks of wood that fit in your hand with a hole in the middle of each wood block will give you something to hook the wire to. One block in each hand with the wire tied in the hole. Long pulls not to fast. Let the wire cool every now and then. Do not let the wire get a kink in it. I've been doing this for 22 years Wear gloves or you'll poke a hole in yourself with the end of the wire. I hope all that's clear.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
Roco71's Avatar
Roco71
I used a guitar string (and it did break a few times) and two blocks of wood on the ends as stated. Then after cutting all the way around I sat in the passenger side and put my feet on the windshield evenly spaced. Pressing forward it came out rather easily.
Old Nov 1, 2011 | 07:07 AM
dembo's Avatar
dembo
When Carglass took out mine they used a special tool.
First they made a hole with a sharp object to pass a piano string sort a like wire through from the inside.
They then positioned that string all around the contour of the glass and fed the end back through the same hole towards the inside (so a lasso all around the glass).
Those two strings where then fixed on a pulley system, one end fixed the other end on the pulley. By whinching the lasso is pulled towards the center of the glass cutting through the bead. They protect the inside of the car with teflon boards so the cord doesn't scratch the trim.
It took 5 minutes and the glass didn't break.
Nick
Old Nov 1, 2011 | 08:55 AM
Denpo's Avatar
Denpo
+1 for metal wire cutting, just make sure the wire NEVER rub again the edge of the windshield.
To windshield removal
Old Nov 1, 2011 | 04:23 PM
Clubby99's Avatar
Clubby99
I tried using deep sea fishing nylon line attached to wood blocks. It worked OK but kept binding. Thin (flexible) long knife worked better. Pull up on the windshield as you cut the bead. Fast and easy. No damage if careful.
Old Nov 1, 2011 | 06:32 PM
Alan 71's Avatar
Alan 71
Hi Chick,
I bought my windshield from 'Classic City Auto' in Minnesota. I ordered it by phone and picked it up at Carlisle. I bought it in 2005. I was pleased with the glass, the etched logo and date, and the ASI stamp. The shading line is a little too distinct, but I wasn't hit for it at the Chapter level.
I'm not sure who the glass manufacturer was at that time.
I didn't have any problems installing it, or the ss trim. I did however use a foam rubber 'damming strip' like the factory did to support the glass the proper distance from the windshield frame; and test fit everything very carefully.
Here's a picture showing the glass installed on the a-pillar. The notes are for someone else whom I sent the picture to a while ago.
Regards,
Alan
Old Nov 1, 2011 | 09:26 PM
1-2-b-67L89
Hi Chick,
Regards,
Alan
Thanks Alan!
