Winter storage
Old Nov 1, 2011 | 01:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ~Stingray
Where would this moisture come from? As long as the tarp is not wet when I put it on where does the problem lie? As far as I know, humidity is not going to cause condensation in the winter months.
The atmosphere contains moisture, even in the winter. Whatever you choose to cover your car with, it has to allow any moisture between it and your paint to evaporate. A waterproof tarp will not do that.
Old Nov 1, 2011 | 05:42 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That's certainly true. Especially in the spring when things start warming up.
I'd imagine you've walked into your unheated garage at some point and noticed the dampness on your daily driver. If not, great.
I think you're over thinking things.
Since you already have a tarp, put it UNDER the car, just a bit of dampness insurance. Moisture seems to rise. What's helpfull if you do find moisture is to slide several 2X4s under the tarp to create an air break. Best surface to actually store on? DIRT! NO moisture problems.
Park the car on the tarp.
Disconnect or remove or just put a battery tender on the battery.
Cover with a breathable cover, even a cheap generic cover is fine.
Leave it alone til spring.
I presently have 10 cars, mostly Vettes, plus my own 4 Vettes, and 2 boats in my barn for the winter.
Some guys simply parked and walked away.
Couple guys disconnected batteries or removed them.
2 guys have battery tenders running.
3 cars have tarps under them, owners choice.
2 guys did a quick fog on the motor.
I imagine some used Stabil, but I don't think that's necessary for 6 month storage.
Some of the cars are even a little dirty!
All are covered(one has an outdoor cover on it that I will probably be removing early spring)
MY Vettes, I have one on the lift and 3 on tarps. Removed the batteries and covered. Windows open for air circulation. One thing I do with mine is drain the oil in the pan now, and refill in the spring. Feel like that at least oils up SOME things in the spring.
EVERYBODY starts right up and drives away come spring!
Old Nov 1, 2011 | 08:34 PM
thoyer's Avatar
thoyer
Originally Posted by Mike Ward
Talk about a combination of bad advice and overkill! That's frightening. Removing wheels? Overkill Soaking rags in oil and draping them over calipers? WTF? Fill the brake M/C- why?
Here's what I've done every winter for my toys since 1971
1) wash
2) change oil and filter
3) fill gas tank, no stabil or other additives
4) park and disconnect/remove battery
5) attach battery to tender
That's it for 5-6 months.
Try to keep your garage at a stabil temperature- either high or low. Fluctuations is what causes condensation and rust.
Yup, works just fine for my 3 cars also. I have a C1, a C3 and a C6 and they all start right up each spring. (Well actually this will be my first winter with the C1, but I expect it will start like the others come spring)You don't need to make short term storage harder then it really is. I do like the idea of a tarp on the floor. I may try that this year.
Buy a decent cover. Don't put a tarp on the car.
tom
Old Nov 1, 2011 | 10:11 PM
'75's Avatar
'75
I park in the garage, take the keys out and put the cover on. In the spring i take the cover off, put the keys in and go for a drive. Repeat in the fall.
Old Nov 2, 2011 | 07:45 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
HAHA no worries at all , if they want it they can have it . Not sure I guess it's just because I have seen other people do it . Monkey see Momkey do!
Old Nov 2, 2011 | 07:52 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Ya, just do a quick google search. Pedophiles are notorious for doing this when they post pictures of themselves. I am in Cyber Forensics and Security. We are taught about this kind of stuff.
