Side Post Battery Master Disconnect Switch
Old Nov 24, 2011 | 09:58 AM
brucksch's Avatar
brucksch
Default Side Post Battery Master Disconnect Switch
Doing so much work on the interior of the car it's time for a side mount battery quick disconnect. I have not found one that will fit in the 81. What are you using and where can I buy it?
Old Nov 24, 2011 | 10:58 AM
fanmanbd's Avatar
fanmanbd
I just had a kill switch that broke the connection to the coil but have removed it since the only place I park the vette now is in the garage.
Old Nov 24, 2011 | 11:05 AM
driddick's Avatar
driddick
My 80 had a cool one mounted on the battery post looked like the big round one on a race car.. it had an on / off switch done buy the previous owner.. I sold the car Tuesday but i'll try to find a picture on the net and post.. worked great!. look professional
Old Nov 24, 2011 | 11:09 AM
Paul L's Avatar
Paul L
This is a Wirth blade unit from JC Whitney. The extra wiring is for a subwoofer.
Old Nov 24, 2011 | 11:13 AM
kdf1986's Avatar
kdf1986
I created my own with one of the round black units that has a plastic key for the on / off switch. To make it fit I bought a short battery cable, extra lugs and cut the cable about 6 inches, spliced a new lug on it, and then bolted it to the unit. The other side was then spliced, lugged and bolted in place.
I now have an easy way to disconnect my battery in case of an emergency, or remove all power for longer term storage.
kdf
Old Nov 24, 2011 | 12:23 PM
noonie's Avatar
noonie
The one pictured is at least 20 years old.
Gama
http://www.gamainc.com/bd.shtml
Old Nov 24, 2011 | 12:34 PM
SteveG75's Avatar
SteveG75
I have one like no one, just orientated a little differently. You can get them at NAPA.
Old Nov 24, 2011 | 12:55 PM
DeadStang's Avatar
DeadStang
I'm looking for one, too, for my '70. Napa has nothing that will work--crappy selection of stuff. Same for Schuck's. I was wondering if one of the Corvette supply places would have something.
Old Nov 24, 2011 | 05:55 PM
SteveG75's Avatar
SteveG75
Sounds like your NAPA folks arent willing to go the extra mile. Here is a good one that NAPA sells.
http://www.napaonline.com/Catalog/Ca...118_0282529018
Should be no more than $15.
Old Nov 24, 2011 | 06:48 PM
brucksch's Avatar
brucksch
$36.56 /ea ouch.
Old Nov 24, 2011 | 07:19 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Originally Posted by brucksch
$36.56 /ea ouch.
I Have this one for 5 years now..
http://www.summitracing.com/parts/MOR-74104/
Old Nov 24, 2011 | 07:27 PM
rosslato's Avatar
rosslato
i've also got this one, works excellent. can get at any local auto parts under $10. saved my back a lot of wear n tear.
Old Nov 25, 2011 | 09:07 AM
69 Chevy's Avatar
69 Chevy
Bought one like this from a vendor at Corvettes at Carlisle a few years ago for $10. He had a cardboard box with hundreds of them. It's everything I expected. Most every CF supporting vendor carries a similar item.
Old Nov 25, 2011 | 10:39 AM
7T1vette's Avatar
7T1vette
That's just like the one I have. Turn the **** 1/2 turn CCW and the power is off. Easy to use and fits in there just fine.
Old Nov 25, 2011 | 11:35 AM
udornf4's Avatar
udornf4
$3.00 each at our annual swap meet here in Myrtle Beach last Spring.
Old Nov 25, 2011 | 12:00 PM
69 Chevy's Avatar
69 Chevy
For $3 did yours come with instructions that it was made on the same equipment that processed tree nuts and eggs? That you shouldn't swallow it unless advised by your doctor? Or feed it to your pet? That it is NOT dishwasher safe?
I thought not. You got the stripped down model for the low, low price of 3 bucks.
Old Nov 25, 2011 | 12:02 PM
nate99's Avatar
nate99
I have a blade type disconnect that I got at Advance Auto Parts. It fits inside the battery box just fine.
udornf4's Avatar
udornf4
Oops - you are correct!
Old Nov 25, 2011 | 01:50 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I once bought the cheap ones and it gave me all sorts of problems, its sometimes lose the contact and the car wont start. I bought the real ones from Amazon.com, can't remember the brand name but its VERY similar to the chinese ones except that it has the US flag on the center of the ****.
To Side Post Battery Master Disconnect Switch
