Engine fan clutch restore question
Old Dec 8, 2011 | 05:53 PM
yyz1970's Avatar
yyz1970
Default Engine fan clutch restore question
After painting the Fan I want to bring up the shine on the clutch How do you clean between all those aluminium fins? I want mine to look like Alan's. Does anyone have any suggestions?
Thanks, Barry
Old Dec 8, 2011 | 06:13 PM
forman's Avatar
forman
you might be able to use steel wool with a Popsicle stick
Old Dec 9, 2011 | 10:46 AM
GPGG70's Avatar
GPGG70
Hi yyz1970,
I used the green scott pads, tooth brush and a drimmel tool brush with dawn and a lots of purple power. Cleaned her up real good.
Hope this helps.
Old Dec 9, 2011 | 06:19 PM
Alan 71's Avatar
Alan 71
Hi Barry,
I used a small very soft brass wire wheel on my bench grinder.
I like the Scotch pads and tooth brush too.
Then just a touch of semi flat clear.
Regards,
Alan
To Engine fan clutch restore question
