correct headers for 79 vette?
Old Dec 10, 2011 | 05:14 PM
McVette's Avatar
McVette
Default correct headers for 79 vette?
Hey guys I have a 79 vette that i want to put headers on, the motor was replaced about 2 years ago with a standard 350 GM crate motor and I have a question for ya.......is there a certain style of headers that i would need to buy for fitting purpose? I did not know if there was a certain style i would need to look at. I saw a listing someone posted in an earlier post that i had about intake manifolds...thanks in advance....
Old Dec 10, 2011 | 06:56 PM
doctorgene's Avatar
doctorgene
Yes Sir; It depends on what you want to accomplish. You can add factory Stainless Steel headers from a 1981 or 1982. They will bolt right on, without changing any head pipes on your existing system, if it is stock. The factory said it added around 7 to 14 H. P. I understand that if you add 2.5 inch exhaust stock manifolds, that you won't notice any different H. P. gain until you reach 5 thousand RPm. I have the factory stainless headers, with 2.5 inch exhaust system from Corvette Central. Do I ever like them, I never turn on the radio, just listen to the rumble. Have a great one. Gene
Old Dec 11, 2011 | 07:11 AM
McVette's Avatar
McVette
hey doctorgene are u talking about short headers......i am thinking about buyin some full length headers
Old Dec 11, 2011 | 08:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by McVette
...are u talking about short headers......i am thinking about buyin some full length headers
He's talking about the factory exhaust manifolds for the 81 and 82 engines. They amount to short tube headers from GM.
Google headers and do a little reading. Tube headers alone won't offer much of a horse power gain. You are also going to want new exhuast pipes - possibly mufflers - to go with your headers.
Ask around about changing spark plugs with headers installed. Could turn out to be more of a PITA than the stock arrangement.
Old Dec 11, 2011 | 08:55 AM
Tim H's Avatar
Tim H
Summit Racing SUM-G9003 - Summit Racing® Headers $109.99.
I have these and they go on with no problems and changing plugs is very easy. they don't rub anything or drag the ground.
Old Dec 11, 2011 | 09:22 AM
McVette's Avatar
McVette
Oh ok thanks Tim I think that is same set I saw in another post
......hey Mike must curious why would u say I might need to change tailpipe also
....the ones on car look almost new?
Old Dec 11, 2011 | 09:30 AM
Kustom8's Avatar
Kustom8
I think Mike was speaking on,if your car is original,then you don't have true duels.74 was the last year for true duels on vettes.
Old Dec 11, 2011 | 09:42 AM
Tim H's Avatar
Tim H
I know these fit because i have used them 3 times now, but I bet there are others like Headman or Dynomax/Flowtech, or what ever The parts catalogs have.
Now I would say Hookers probably fit great but the price is higher for the same thing other than the "Hooker" tag on the tube.
Old Dec 11, 2011 | 10:08 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
First of all, in order to install a set of full length headers, you're going to have to modify the exhaust pipes somewhat, so they'll connect to the headers.
Secondly, while headers will provide a flow increase over the stock manifolds, this just moves whatever restrictions there might be, to somewhere else downstream. Most small block C-3s have 2.25" pipes, IIRC. Big blocks had 2.5" pipes, which naturally, will flow better, and if installed on your small block car, will allow your headers to perform better.
Don't forget, after installing headers, you may need to re-jet your carb, to take into account the better flow of the headers.
Old Dec 11, 2011 | 02:06 PM
Priya's Avatar
Priya
Are those for 4 speed or automatic?
Old Dec 11, 2011 | 03:46 PM
scottyp99's Avatar
scottyp99
I haven't used these headers personally, but have read more than a few posts by folks that really like 'em. Haven't heard anybody complain about 'em. They are what I am planning on using in the near future. And the price is so right, it don't get no righter!!!
Scott
Old Dec 11, 2011 | 06:56 PM
McVette's Avatar
McVette
sounds good.... looks like I am gona give them a try and ohh i guess I should have mentioned that the PO took the cat out and they are straight pipes out the back with just mufflers
Old Dec 13, 2011 | 08:43 AM
Easy Mike's Avatar
Easy Mike
....hey Mike must curious why would u say I might need to change tailpipe also...the ones on car look almost new?...
Do a little homework on optimum exhaust pipe diameter to go with your headers. Too small is bad; too big is equally bad. Have you measured your existing pipes?
Old Dec 13, 2011 | 08:48 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
you could always go easier and pick up a set of 2.5" ram horns and keep a stock look. I have seen them for about 120 a set...They do have the early ear on the front but that's easily removable...
Old Dec 13, 2011 | 09:47 AM
qwank's Avatar
qwank
Don't bother with those stock GM stainless manifolds, they are junk.
I also have those Summit headers and they fit perfect and went in from the bottom with no problems. I stripped the black paint off them and painted them with VHT paint before the install though.
Old Dec 13, 2011 | 10:42 AM
Priya's Avatar
Priya
Old Dec 13, 2011 | 03:10 PM
79vetter's Avatar
79vetter
I'd also like to know this..
To correct headers for 79 vette?
Old Dec 13, 2011 | 03:32 PM
scottyp99's Avatar
scottyp99
Yes.
Scott
Old Dec 13, 2011 | 03:39 PM
Priya's Avatar
Priya
Originally Posted by scottyp99
Yes.
Scott
How about an unambiguous response?
Old Dec 13, 2011 | 03:55 PM
scottyp99's Avatar
scottyp99
No.
Scott
