VIN / Matching Numbers
Old Dec 23, 2011 | 10:59 PM
77VetHead's Avatar
77VetHead
2nd Gear
Default VIN / Matching Numbers
Ok I am about to buy a 77 Vet. I am told it is matching numbers, but when I go look at it I want to confirm. I know I can compare the VIN on the dash to that on the driver side door and on the frame under the driver side door. My first question is for the one on the engine .. where is this located? ... I assume it should be fairly in plain sight, but wanted to see if someone could point me to the location so I don't have to hunt for it. My second question is, if car VIN and Engine VIN match .. is that a matching #'s car? .. or do I have to look for something else .. i.e. the transmission? Any other tid bits as far as what I should look for and where would be appreciated .. thanks in advance Eric
Old Dec 23, 2011 | 11:12 PM
scottyp99's Avatar
scottyp99
The whole "numbers matching" thing means different things to different people. If you want to make sure the engine is the original engine, look for a stamp pad on the front, passenger's side of the block, right in front of the cylinder head.
Scott
Old Dec 24, 2011 | 10:15 AM
Jay-Dog's Avatar
Jay-Dog
The basic numbers matching idea is the VIN & engine stamp block, verified on pass side front pad. For real $ provenance, you're talking about oe belts, hoses, carb, everything. In other words, nothing has ever been replaced, low mileage queen. Some samantical difference would be better, like "systems numbers matching". This can be a hot topic for some. tread lightly.
Old Dec 24, 2011 | 10:21 AM
Alan 71's Avatar
Alan 71
Hi 77,
The matching numbers business is a very deep hole.
Generally people are referring to the numbers cast into, and stamped on, the engine being appropriate for the car it's in. Many people go no further than this.
The next question might be.... is this in fact the engine that was in this car when it left St. Louis... and how might that be determined? That's a whole new level of numbers matching.
The next step would be the other parts of the car that had part numbers and date codes that would be appropriate for this car's production date. There are hundreds of parts that have some part number and/or date code on them.
Many other parts can be identified by their configuration alone since may parts were changing during production.
The engine, transmission and frame are the only parts that have the car's VIN derivative identifying them.
You have to remember that numbers matching matters a great deal to some people and not at all to many others.
Regards,
Alan
Here's an example of 2 rather obscure dated parts. The birdcage and an interior door panel. No way to check these unless the car is apart; but nice to find.
Old Dec 24, 2011 | 10:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 77VetHead
...I know I can compare the VIN on the dash to that on the driver side door and on the frame under the driver side door...
VIN is not on the dash or the door. VIN is on the driver's windshield post. Trim Tag is on the driver's door hinge post.
You are not likely to be able to see the frame stamps.
...My first question is for the one on the engine .. where is this located? ...
VIN derivitive stamp and engine code are on the pad on the block at the front of the right head. AIR pump might make things a little difficult to see.
VIN derivitive is also on the transmission if you want to crawl under and look for it. Most folks are tickled is the VIN derivitive on the engine pad matches the VIN plate.
Take a note pad, pen, and a flashlight when you see the car.
Good luck.
Old Dec 24, 2011 | 11:10 AM
BKarol's Avatar
BKarol
Helped a friend lower the body on his 71 frame this past weekend. The vin is stamped right below that bolt. Driver's side rear. Area would need to be cleaned, tire off and a mirror would help. The whole vin is not there only a portion:
Old Dec 24, 2011 | 06:37 PM
vettebuyer6369's Avatar
vettebuyer6369
Understand that the main semantics issue is the difference between "matching" and "correct." The VIN derivative on the passenger side head machined pad must MATCH the VIN fiound on the VIN plate on the windshield pillar as well as the title and the frame if you could find it (that one is hard).
Other matching issues (not really numbers) are the paint and interior matching the trim tag codes. There is also a VIN derivative on the transmission that matches the body VIN, and a really, really good detective can tell a lot by the way the trans stamp compares to the pad stamp, but thats for another day.
All the other numbers issues are matters of "correctness." An 010 block can be "correct" for a 1969 Vette, but it doesnt "match" anything. The same goes for serial numbers found on alternators, expansion tanks, radiators, etc, etc. All these parts can be replaced. All these parts can have numbers that can be "correct" for a certain car, often supported by proper date coding... but none of those numbers "MATCH" anything. The semantics issues arise when people confuse numbers that can be correct and say they "match."
Ill follow up with some photo examples.
Last edited by vettebuyer6369; Dec 24, 2011 at 07:09 PM. Reason: typing worse every day
Old Dec 24, 2011 | 07:06 PM
vettebuyer6369
Here's a couple pictures of numbers that "match":
The first is the engine assembly pad number and the VIN derivative. If you compare the VIN derivative to the VIN on the car body and title, they match.
The second is a transmission stamp and VIN. Here as well, the VIN will match the VIN on the car.
Here's a couple other numbered parts:
An engine casting (serial) number, a casting date in an engine, and a carb number and date.
People will commonly say these are "matching." They arent. They are "correct." The 739 serial engine IS from an original number engine in a car, but that serial alone is found in many Corvettes. That number is correct for the model, but "matches" nothing. Same for the date and the carb part number and date. Date will need to conform to a certain format and may fall in line with other dates on the car, within appropriate time frame variances. All in original cars, but those numbers do not match anything, like a pad VIN matching a body VIN. They are simply correct for a model, and could be used in any number of Corvettes.
Old Dec 26, 2011 | 11:36 AM
77VetHead's Avatar
77VetHead
2nd Gear
Awesome, Thanks !!! This is the info I was looking for and a lot of great info it is !!! This will help me in my potential purchase. Thanks again !!!
To VIN / Matching Numbers
