HELP ! tachy not working
Old Jan 10, 2012 | 06:47 AM
guzman31's Avatar
guzman31
Default HELP ! tachy not working
Hello everybody,
I changed the 73' cable tachy for an 77' electronic tachy. I have a problem with the connections at the back. We have 3 connectors in position like a letter L, the middle connector is the signal from the "Delco-Remy", the others 2 are the ground and the + 12 V.
My question is: where is connected the ground, where is connected the + 12 V in the tachy because we can reverse the 2 wires !! and burn the tachy.
Thank you.
Old Jan 10, 2012 | 12:07 PM
7T1vette's Avatar
7T1vette
Do you also have the tach control circuit board and the tach filter for getting that tach working? If not, you won't get it to read anything.
Old Jan 10, 2012 | 12:15 PM
guzman31's Avatar
guzman31
Yes I have the control circuit board, I think you mean the electronic card fixed in the tach ? for the filter no I don't.
On the electric diagram we dont see any filter on the tach circuit where si it ?
Old Jan 10, 2012 | 12:32 PM
pik's Avatar
pik
The filter is supposed to be in-line in the wire coming from the distributor.
Old Jan 10, 2012 | 12:44 PM
guzman31's Avatar
guzman31
OK I explain my problem:
I connect all to the tach (+12V, ground and the signal from distributor), when I turn the key, the needle goes to the 0 position that's OK but when I start the engine some smoke get out from the tach, I stop all immediately. I didnt insert any filter between the distributor and the tach.
Do you think that's the origin of start burning ?
Old Jan 10, 2012 | 12:46 PM
guzman31's Avatar
guzman31
I was thinking that I reversed the +12V and the ground but I'm not sure of the back connections tach
Old Jan 10, 2012 | 03:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by guzman31
...when I start the engine some smoke get out from the tach...
I would not be surprised if you burned out your tach board.
Old Jan 10, 2012 | 08:18 PM
BKarol's Avatar
BKarol
I haven't had a tach filter in years, so doubt that not having one would make smoke.
You can see it here in the product illustration:
http://www.ecklerscorvette.com/corve...1975-1989.html
Old Jan 10, 2012 | 08:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you hook power up to the wrong wire with a factory board you have blown the board... Here are the correct connections for the 1975-1977 tachometer. A new US made tach board is 58.00 http://willcoxcorvette.com/product_i...ducts_id=26840
And here is how to install a new board if you need one..
1975-1977
Old Jan 10, 2012 | 11:34 PM
7T1vette's Avatar
7T1vette
Another 'good reason' to own the AIM and the Chevrolet Chassis Service Manual (which has the electrical schematic in it). Hope just the circuit board was toasted.
Old Jan 11, 2012 | 12:07 PM
guzman31's Avatar
guzman31
Thank you Willcox corvette, your pics are very helpfull for me, that's the response I was waiting.
But the electrical diagram in the Chevrolet chassis service manual 1977 is not showing the sames connections on the tacho connector.
I explain: the switched voltage and the tach are reversed. That's why I burned my tachometer.
Old Jan 11, 2012 | 06:05 PM
7T1vette's Avatar
7T1vette
Interesting. The coil wires shown in the 1971 GM Corvette electrical schematic are reversed, as well. Dyslexic draftsman????
Old Jan 11, 2012 | 08:31 PM
0Willcox Corvette
Former Vendor
7t1vette... We had a customer recently that brought us a 71... It was wired backwards at the coil! That might explain why he wired it that way..
There is a orange wire that runs from the ignition switch to the fuse panel missing from the schematics on 1970-1975 schematics.. I've added it to all our schematics.. but what a pain. Nuts.. what one wire drawn wrong can do! Case and point.. the 68 schematic is by far the worst one every.
Old Jan 11, 2012 | 10:11 PM
7T1vette's Avatar
7T1vette
Another point of interest....
All of the schematics in the 1971 Chevrolet Chassis Service Manual (full-sized body and down) are correct on the way the coil is wired....except for the Corvette. The same draftsman probably did all of them. Makes you wonder---
To HELP ! tachy not working
