transmission wire
Old Jan 12, 2012 | 04:39 PM
hensley73's Avatar
hensley73
Default transmission wire
what is the electric wire that runs from the transmission to the firewall on a 1980 corvette 350 turbo? If it is an electric wire is it hot all the time or only when the switch is on ?
Old Jan 12, 2012 | 08:15 PM
7T1vette's Avatar
7T1vette
Might be the signal wire to engage the converter lockup clutch....can't remember what year the lockup feature began on C3's.
Old Jan 12, 2012 | 09:33 PM
scottyp99's Avatar
scottyp99
Yep, that's probably what it is. I think The lock-up converters only came on California 'vettes in '80, and the Cally 'vettes in '80 all had 305s in them. Check it out, I hope I'm wrong.
Scott
Old Jan 13, 2012 | 06:57 AM
HeavyMetalHawk's Avatar
HeavyMetalHawk
I have a 1980 350 with lock-up converter. But not working as far as I know. but has the wire over the pan on the LH side and goes to the firewall and connects to the Vacuum switch there
Old Jan 13, 2012 | 09:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by scottyp99
...I think The lock-up converters only came on California 'vettes in '80...
Nope. My 80 L-82 has the lock up converter.
Old Jan 13, 2012 | 03:17 PM
scottyp99's Avatar
scottyp99
Well, I guess I stand corrected. My 1980 L48 auto does not have a lock-up converter. So, does anybody know how they decided on which cars got lock-up and which cars didn't? Did they just flip a coin on the assembly line?
Scott
Old Jan 13, 2012 | 03:34 PM
HeavyMetalHawk
Scott
Maybe the PO. swap your tranny... Or could depend on the factory the caf was made
Old Jan 14, 2012 | 11:19 AM
69 Chevy's Avatar
69 Chevy
Originally Posted by HeavyMetalHawk
Or could depend on the factory the caf (car?) was made...
All 1980 models were made in St. Louis Missouri, USA. Also known as 'the birthplace of legends.'
Old Jan 14, 2012 | 11:41 AM
HeavyMetalHawk
My bad... both.. had to be car but sometimes I reply like now from my phone and sometimes driving. and I thought that was in the 1980 when the two plants work at the same time but I guess that it was on the 1981
Old Jan 14, 2012 | 04:16 PM
scottyp99's Avatar
scottyp99
Original Transmission. Possible the knucklehead who owned it before me, might have ripped out the wiring for it, I'll check a little closer, and see if it has that little 4-prong female fitting for the wiring, if it does, I'll let ya know, and purchase a new harness to get the lockup working.
Scott
Old Jan 14, 2012 | 04:57 PM
HeavyMetalHawk
Scott
Mine was diaconected also. but had the harness aside. after fighting and some few burns I conected again. but got nothing today I cleaned the conections on the vacuum conector thats on the firewall in front of the driver side and now its working
To transmission wire
