my 69 vin any help decoding?
Old Jan 12, 2012 | 07:24 PM
sauto1985's Avatar
sauto1985
Default my 69 vin any help decoding?
Relatively new to this forum, but ive owned 6 different vettes. I was wondering if anyone can share there vin number decoding knowledge on my 69 coupe. I bought it in boxes no motor or seats but most everything else was there i believe 427 390 hp 4 speed car. the vin is as follows 194379s715204.Thanks for any help.-------skip
Old Jan 12, 2012 | 07:38 PM
BKarol's Avatar
BKarol
Here is the vin decoding.
http://corvetteactioncenter.com/specs/c3/1969/69id.html
Old Jan 12, 2012 | 07:43 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Not much to glean from the vin of the 69 cars. Your car was #15204 of 38762. This vin was built in mid Jan of 1969 according to the black book.
The trim data plate on the door jam will give you the interior and exterior color, as well as the build date.
Also says it is a coupe, as you stated.
Other than that, you will need the bbuild sheet for an options list.
joewill's Avatar
joewill
1= chevrolet
94=corvette
37= 2 door sport coupe
9=1969 year
s=saint louis, car was built in St. louis
7=again corvette
15204= a number between 1 and 38762 determining the sequence number built, the 15,204th car built.
no way to tell engine or trans.....
Old Jan 12, 2012 | 07:51 PM
69VetteFla's Avatar
69VetteFla
http://www.corvette-web-central.com/...INdecoder.html
Corvette VIN Decoder 1965 to 1971
13 Digit VIN Explanation
Example: 194375S100001
Sequence
Number Code Description
1 GM division 1 = Chevrolet
2 Car line or series 9 = Corvette
3 Engine type 4 = V8
4 & 5 Body style 3 & 7 = two door coupe
6 & 7 = two door convertible
6 Model year designation from GM
5 = 1965
6 = 1966
7 = 1967
8 = 1968
9 = 1969
0 = 1970
1 = 1971
7 Final Assembly Plant "S" = St. Louis
8 to 13 Production Sequence Number 100001 - 121801
Old Jan 12, 2012 | 07:53 PM
sauto1985's Avatar
sauto1985
Originally Posted by joewill
1= chevrolet
94=corvette
9=1969 year
7=again corvette
Thanks for help guys.
Old Jan 12, 2012 | 07:58 PM
sauto1985's Avatar
sauto1985
Its a 4speed car ,i have numbers matching trans, also has hd rear end yokes and seems to be original bb 427 hood--just gueesing 390hp.Ill see this sping when tank is dropped if build sheetis there and readable.
Old Jan 13, 2012 | 12:44 AM
vettebuyer6369's Avatar
vettebuyer6369
Whats the #'s on the engine pad?
Old Jan 13, 2012 | 03:38 AM
sauto1985's Avatar
sauto1985
i bought it no motor included
To my 69 vin any help decoding?
