'69 Carpet Install
Old Jan 26, 2012 | 12:15 PM
tomvanparis's Avatar
tomvanparis
Default '69 Carpet Install
This weekend I plan to install carpeting purchased from Al Knoch. Questions:
1. Where's the best place to start? Rear compartment and work towards the front? Or front to back?
2. For the carpeting in the rear compartment that is on the sides....do those pieces go first followed by the interior deck piece (overlaying slightly the bottoms of the side pieces)?
Old Jan 26, 2012 | 01:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Rear to front.
Wheel house carpets first in the rear.
Use your old carpet as a template for the new.
Good luck.
Old Jan 26, 2012 | 02:56 PM
tomvanparis
Rear to front.
Good luck.
Thanks Easy. I presume modest amounts of patience too
Old Jan 26, 2012 | 03:20 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I'll offer a suggestion on the wheel house carpets. Lay them out in the sun to heat up a bit. Much more flexible when installing.
And yes - a "bit" of patience will go a long way!
Old Jan 26, 2012 | 03:27 PM
Alan 71's Avatar
Alan 71
Hi TVP,
NO MATTER how sure you are that you're trimming the right amount.... only trim a little at a time... once you've cut too much, it's a bit difficult to stick the piece back in place.
Patience really does pay off.
Regards,
Alan
Old Jan 26, 2012 | 04:13 PM
tomvanparis
Originally Posted by Alan 71
Hi TVP,
Regards,
Alan
Alan
Thanks for the insight. I plan to see how close the new pieces match up to the old...trim a bit then position...trim more as needed. Then go to the next piece and so forth...and position all pieces in the car to see how it all matches up BEFORE glueing them down
TVP
Old Jan 26, 2012 | 04:25 PM
Easy Mike's Avatar
Easy Mike
Nope. BIG amounts of patience.
Old Jan 26, 2012 | 04:34 PM
70BBvert's Avatar
70BBvert
Along with trimming small amounts at a time. A heat gun will help soften up the backing to help eliminate wrinkles.
I spent an entire day on each one of the pieces over the wheel wells and still couldn't get rid of all the wrinkles . Wish I never saw Alan's carpet installed
Can never live up to that standard
Jim
Old Jan 26, 2012 | 05:04 PM
FKING1's Avatar
FKING1
Putting Dynamat in my 70 Coupe.
Putting carpet back in is killing my back working on hands and knees in the back..
Patience , patience and more.
Old Jan 27, 2012 | 05:06 PM
FKING1's Avatar
FKING1
There are 3 rubber push in type fasteners that hold the carpet against the back wall.
Can't get them in no matter how hard I try.
Is there a trick to getting them in?
Old Jan 27, 2012 | 06:31 PM
keeks2915's Avatar
keeks2915
Advice from this forum made my 69 carpet install relatively easy.
Great advice so far. The absolute best thing I did was prop up the next chunk of carpet in front of the gas fireplace for half an hour.
Super easy to work with when warm. Hard to lay out in sun in the middle of winter.....
Old Jan 27, 2012 | 06:33 PM
keeks2915's Avatar
keeks2915
Ky jelly and a screw driver with the tip ground off.
Old Jan 28, 2012 | 09:06 AM
FKING1's Avatar
FKING1
Thanks, Will try.
Silicone spray did no good.
Old Jan 28, 2012 | 09:44 AM
Alan 71's Avatar
Alan 71
Hi f,
Besides k's suggestions I put the plugs in hot water to soften them up a bit.
I have a nice collection of plugs with tips that have a split in them.
The plugs on the driver's side front are a bear to get at, and also push through.
Regards,
Alan
Old Jan 28, 2012 | 10:27 AM
Big Block Dave's Avatar
Big Block Dave
After doing this job this past summer, I couldnt agree more with Alan's posts. I got a little scared at a couple of times that I had overtrimmed, but fortunately it was all concealable by the center carpet, and the package tray lid.
Definitely start from the back to front, and work in an area with consistent lighting....when you are working in the back area, its like a cave...if you pick your head up and have sunlight in your face, readjusting to the cave lighting is a b#tch.
Also, have patience with the holes for the t-top retention pieces in the back, and all seatbelt related areas [especially if you have covers over the underseat retractors]
Please also consider some sort of heat reflective carpet underlayment...you will thank yourself this summer
Old Jan 28, 2012 | 10:27 PM
RobRace10's Avatar
RobRace10
And you can buy the rear wheel houses separate (at least the ones Willcox sells) after you screw them up, no reason to ask me how I know!
Old Jan 31, 2012 | 05:16 PM
FKING1's Avatar
FKING1
Some info.
All the tips did not work.
Took a 1/4" Electric Drill Motor (no drill) chuck closed, started the rubber fastener in the hole, put the chuck against the button head and cycled the motor.
Success!!!
Old Jan 31, 2012 | 05:29 PM
Alan 71's Avatar
Alan 71
Hi f,
THIS sounds like it's worth a try!!!!
Regards,
Alan
Old Feb 13, 2012 | 05:22 PM
FKING1's Avatar
FKING1
Update on my carpet install. Used old rears over the Dynamat.
New fronts are in. They were way too wide and had to trim to fit, little at a time. (Ecklers).
Locating spots for seat belt bolts and seat attach a hassle. Learned to cut holes on pass side before final fitting which I did not do on drivers side.
Plan to put in the Corbeau drivers seat tomorrow.
To '69 Carpet Install
