Bearing endplay....please explain
Old Jan 28, 2012 | 08:21 PM
DJ Freddie's Avatar
DJ Freddie
Default Bearing endplay....please explain
What are you actually measuring for bearing endplay?
Freddie
Old Jan 28, 2012 | 08:53 PM
Mike Ward's Avatar
Mike Ward
End play in the bearings.
Old Jan 28, 2012 | 08:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Technically, it is the amount of clearance (freeplay) between the inner and outer bearings in relation to the inner and outer race.
Old Jan 28, 2012 | 11:34 PM
7T1vette's Avatar
7T1vette
Axial running clearance....
Old Jan 29, 2012 | 10:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Willcox Corvette
...Technically, it is the amount of clearance (freeplay) between the inner and outer bearings in relation to the inner and outer race...
Too much and (less so) too little endplay are undesirable things.
Old Jan 29, 2012 | 12:50 PM
bobbarry's Avatar
bobbarry
Unless you are referring specifically to Crankshaft endplay, which is determined by the thrust-flange on one main bearing and the thrust-surface on the crankshaft. You are measuring how much the crankshaft is able to move forward and back in the main saddles.
Old Jan 29, 2012 | 04:35 PM
DJ Freddie's Avatar
DJ Freddie
Thanks,
Freddie
To Bearing endplay....please explain
