72 Restoration - Engine Looking Good
Old Jan 29, 2012 | 06:59 PM
PhilaScott's Avatar
PhilaScott
Default 72 Restoration - Engine Looking Good
Working towards 2nd flight award. Added date correct, numbers correct carb, TSC and Idle solenoids, hoses etc. etc. Car is running better with everything that gets done!
Click any pic for a larger version.
I know being able to find nice clean pics helped me through this process -- so thought I'd put these out there for anyone else looking for reference.
Old Jan 29, 2012 | 08:02 PM
69FASTFUN's Avatar
69FASTFUN
That looks good. A couple of observations that I see and I may be wrong.
1. I think the oil fill on the 72's was a rubber push in plug not the twist in type
2. Master cylinders had the two bleed screws
3. water pump has the plug in it were the by pass was and smallblocks did not have that.
(I think I have a correct watter pump for your year)
Old Jan 29, 2012 | 09:46 PM
PhilaScott's Avatar
PhilaScott
Thanks.
72 (late) could have either cap. I do have both. Metal one as correct markings.
Water pump was replaced. If I find a correct replacement, I'd consider changing it.
Old Jan 30, 2012 | 08:39 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Scott,
You might think about taking a run out to Geese's Auto Farm, for some of the small original parts (tower clamps, vacuum hoses etc.). It's a you pull it type of junk yard.
WB
PS: You're making nice progress, I'd bet you'll be closer to a Top Flight if you keep this up!
Old Jan 30, 2012 | 02:48 PM
Alan 71's Avatar
Alan 71
Hi Scott,
I clicked on one of your pictures and was lead to your PhotoBucket album.
You certainly have made a LOT of progress!!!!
Nice Work!
Regards,
Alan
Old Jan 31, 2012 | 12:35 PM
PhilaScott's Avatar
PhilaScott
Originally Posted by Alan 71
Hi Scott,
Nice Work!
Regards,
Alan
Thanks... Definite work in progress...
Starting to see the shiny part of the diamond...
Old Jan 31, 2012 | 09:12 PM
texaswilkins's Avatar
texaswilkins
Certainly looks better than my 72. Good luck on that flight award.
Bill
Old Jan 31, 2012 | 09:25 PM
Mike Ward's Avatar
Mike Ward
Depending on the VIN, that pump might be correct as-is. This is a 5 star bowtie car that belongs to a friend:
http://rides.webshots.com/photo/2402...10410527uhmTxk
Old Jan 31, 2012 | 09:34 PM
PhilaScott's Avatar
PhilaScott
Looks like Pat H's car....
To 72 Restoration - Engine Looking Good
