AC Condensor
Old Feb 7, 2012 | 12:41 PM
TWINRAY's Avatar
TWINRAY
Default AC Condensor
what are the things to look for to determine if my oem condensor is OK?
Old Feb 7, 2012 | 12:51 PM
Sully1882's Avatar
Sully1882
from what I understand the OEM ones are very poor in function and you are better off upgrading to a newer style crossflow type.
Sully
Old Feb 7, 2012 | 12:55 PM
TWINRAY's Avatar
TWINRAY
Sully
Will take that into consideration - thanks
Old Feb 7, 2012 | 12:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Does it have a hole in it? Was it leaking when you took it off?
Old Feb 7, 2012 | 04:22 PM
jcloving's Avatar
jcloving
I switched to a parallel flow unit. It is less restrictive than my old one. I tested by blowing into it...sure enough, it flows easier.
Old Feb 7, 2012 | 05:29 PM
lonebull's Avatar
lonebull
Default ac condenser
Your orig. cond. may well be operational. That's the good news. The bad news is that sone 30+ years have passed & your old tube&fin cond. dosen't hold a candle to the newer cond. Will yours wrk?- probanly yes. Willit perform as well as the newer designs? no. If you live i MI it probably dosen't matter much. If you live in the South it makes a world of diff. Heres a quote fro the Vintage Air wewbsite on cond. "The importance of this unique new micro tube design & its improved reliability cannot be overemphasized...provides up to 40% more capacity than a comparably sized tube & fin cond." Also says on another website they dissipate much more heat. On top of that they make one that is almost a drop in tor a c-3 vette (requires different fittings probably- did on mine.) So if you're serious about air conditioning it at least deserves some study on your part. Look at it this way- if you choose to upgrade the ac/heat in your home do you go with a high efficiency heat pump or do you look for a NOS unit like the one you have? If you are a Corvette "purist" you are in a bad situation because they don't make a replacement cond. that is a high efficiency unit. If you're sticking with R-12 the orig. cond will deliver just what it did when it was new provided the rest of the system was also brought uo to fact. spec. That's the long & the short of it. Thanks for hearing me out. I don't sell auto. ac units but I just replaced my entire factory unit with an Old Air Hurricane unit this past summer & my vent temps went from 58 degrees to 43-45 degrees. If people are spending $300 or more to bring down cabin temps & they are also looking at ac upgrades then changing the cond. (& the compressor to a Sanden unit) just makes sense. just my 25 cents. lonebull
Old Feb 8, 2012 | 10:41 AM
TWINRAY's Avatar
TWINRAY
Thanks for the detailed reply. I will look into the Hurricane unit. My AC wasn't functioning correctly when I started this resto in 2008. I think it was (at least) because that the "muffler" tube was leaking because it wasn't a 1 piece unit and was held on with a worm clamp. Local shop previously did a evac and recharge and the AC worked till the end of the season. It was just for 2 months (this was prior to 2008) then it went into winter storage and it didn't work the next year. I went back to the shop and the guy told me it was probably because of the worm gear attachment leaking. He sorta put the blaim on me. I told him that he should have mentioned that I needed another hose before charging me $300 for AC repair that probably wouldn't hold out. I now know better to return to him for AC work - this "mechanic" was eventially fired from the shop. I don't want a R12 unit. I'd rather have a 134 (or is there something now even better?). I figured I need a new condensor - in fact, I (probably) need everything new. I'd rather "bite the bullet" now, get it done right, and not worry about it. Thanks again for the info.
Old Feb 8, 2012 | 06:14 PM
lonebull's Avatar
lonebull
I've done some posting on this but others have gone into the ac swap in a lot more detail than I have- just do some "ac swap" searches or similar wording & you should find a lot of info. I still have trouble posting photos but I could email you some if you get into it. I had a small tank radiator & the condenser laid right in- had to fab attachments &flat pcs. to force air into the cond. & rad. It's hard to see in the pics but it looks good. The Hurricane unit is pictured on the website with dimensions-it's like a rectangular box wiyh the fan on the end the vent tubes across the top- easy to make a cardboard box identical to the dimensions in order to see what it would look like. Most go with the Vintage Air but I have used both over the yrs. & decided on the Hurr. I won't lie to you it's a big job just getting the oem box out & the ducts are a pain too. The Hurricane unit hangs a little low but looks fine &there is NO toe cove issues. Would be glad to disvuss it if you decide to do it . PM me for pictures with your email. I had a low mileage oem unit but it just wasn't cutting it- not enough airflow- notlow enough temps at the vent. lonebull
To AC Condensor
