C3 Max Tire Size
Old Feb 15, 2012 | 10:04 PM
fberus's Avatar
fberus
Nut Job
Default C3 Max Tire Size
What is the widest practical tire that will fit in the rear wheel wells of a C3? I have a '69 and plan on using the stock 15x8 rallye wheel rims. I want to get as much rubber on the road as I can to handle that 460 ft/lbs of torque. ;-)
Old Feb 15, 2012 | 10:34 PM
Billem's Avatar
Billem
On my '74 convertible I'm running 255/60/15 all the way around. No problems. Bill
Old Feb 16, 2012 | 09:44 AM
HeavyMetalHawk's Avatar
HeavyMetalHawk
In my 80 I have 275/60/R15 in the back and waiting for my 255/60/R15 in the front... not any issue at the moment
Old Feb 16, 2012 | 10:00 AM
69 Chevy's Avatar
69 Chevy
275/60/15" on the rear of my '69 with F41 suspension, which lowers ~1" from stock, and the OEM trailing arms. I did have to pull the e-brake cables away from rubbing the inside of the sidewalls with springs...no big deal.
Old Feb 16, 2012 | 01:39 PM
MakoShark77's Avatar
MakoShark77
St. Jude Donor '24-'26
Did you guys re-locate the E-brake bracket on the trailing arm? If so, where to?
Old Feb 16, 2012 | 02:19 PM
mffi115's Avatar
mffi115
Default Pix?
Could you post side and rear view pics of the 275/60/15s, please? I'm not worried about the e-brake cables since I have the VB&P offset trailing arms.
Old Feb 17, 2012 | 09:43 AM
69 Chevy's Avatar
69 Chevy
No pics with these tires and OEM fenders. I installed flares in the meantime. Not because of clearance problems but to try and alleviate the road rash from highway debris, mostly the front. And it wouldn't look right with flares only on the front.
Old Feb 17, 2012 | 10:15 AM
HeavyMetalHawk
This are the ones that I took on the run
Old Feb 17, 2012 | 03:53 PM
Vesa's Avatar
Vesa
255/50/17 all corners, plenty of room...
Old Feb 17, 2012 | 10:06 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you're stuck on using 15x8 wheels, the limiting factor isn't the fender wells. For those, the 255/50R15 is pretty much the optimal tire. Bigger ones can be fitted, but anything very much wider on an 8" rim is only going to bring increasing sidewall instability into play (read, "adversely affect handling"), not to mention tend to look like balloons. If you need to put more rubber on the ground IMHO you really need to think in terms of a larger wheel/tire package, then you can properly fill those fenders with something that will actually gain you something. My $.02
Old Sep 20, 2013 | 09:43 AM
11echo's Avatar
11echo
3rd Gear
I have 255/60/15 on my 69 car (stock rally rims); in the rear they work well! BUT in the front I have a problem with them just coming in contact with the frame when I turn the car to the max limit of the steering wheel! Also I have a slight nose up standance, so I'm looking at what tire (60 series) will bring the nose down abit and small enough to elimination the rubbing.
Old Sep 20, 2013 | 10:41 AM
540 vette's Avatar
540 vette
I have 275/60/15 on the stock 80 rims on the back of my car. They fit fine and don't look like balloons.
Old Sep 20, 2013 | 09:45 PM
TheSkunkWorks
OK, I'll admit (if only this once ) that my opinion of 275's looking like balloons on 8" rims is just that, an opinion. So please allow me to offer a more responsible post, without the jab clouding the point...
However debatable might be individual tastes regarding appearances, it remains that the optimum wheel width for a 275/60R15 is more in the 9-9.5" range. Yes, for the sake of argument, the TRA sizing standard for this size tire may be only 7.5", but that's only a reference point for establishing advertised section widths, rather than a recommendation for performance oriented* wheel/tire fitments.
* As from the perspective of carving up the curves.
Old Nov 10, 2013 | 08:34 PM
AeroDog's Avatar
AeroDog
From: Carolina raised but in Loveland CO for tha duration
What rims are you using? I'm having a hard time determining which rims will work with my 68. Sorry for the time lag.
Jerre
Old Jan 18, 2017 | 06:31 PM
Glengoro's Avatar
Glengoro
3rd Gear
Thanks for the fast response - my problem is its a 68, so 7 inch rims. I'vre been told it will rub on the parking brake bracket?
Old Jan 18, 2017 | 06:34 PM
540 vette's Avatar
540 vette
Fast response to what? The last post was 2013.
Old Jan 19, 2017 | 12:54 PM
ENCSDOUG's Avatar
ENCSDOUG
NT55R P275/60/15 in the rear on 15X8's AR TT's. Plan on going with AR TT 15X9.5 this summer.
Front 235/60/15. Back 275/60/15
To C3 Max Tire Size
Old Jan 19, 2017 | 04:46 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Suggest you relocate the pb bracket to the top of the trailing arm. It wouldn't be wise to go with a tire too wide on a 7" rim.
Old Jan 19, 2017 | 04:58 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
if you want fat back tire, swap out the 68- 7" rims in the back, for 69 - 8" wheels
if you stick with stock wheel offset you can go 255 without moving the emergency bracket.
you will be closer to your leaf spring, (limiting factor)
Old Jan 19, 2017 | 05:02 PM
MelWff's Avatar
MelWff
Default Dead Thread
He replied to the wrong thread, the correct one is below
https://www.corvetteforum.com/forums...ze-for-c3.html
