Jacking up front end
Old Feb 21, 2012 | 11:29 PM
TPI BOY's Avatar
TPI BOY
Default Jacking up front end
Where would be the best place to put a
floor jack to jack up the front wheels both
at the sametime.
Old Feb 22, 2012 | 02:09 AM
aussiejohn's Avatar
aussiejohn
Default NOT Under The Crossmember!!!!!!
TPI BOY,
You're a smart man for asking here, as the Corvette frame was never designed for jacking under the Xmember. Don't ask me how I know! You MUST jack it up where it tells you in the Workshop Manual, that is, under the frame rail about five inches in front of the vertical front door gap and about three inches in front of the rear door gap.
To get both front wheels up, you need to jack from both sides. Unless you design a bracket that will protect the Xmember and allow you to jack it up from the front, then DON'T!!!
Regards from Down Under.
aussiejohn
Old Feb 22, 2012 | 07:14 AM
Tim H's Avatar
Tim H
I jack mine up on the cross member right in front of the engine so it goes up even then put jack stands under the frame.
If you bend that big piece of metal then your car is going to fold in half while driving anyway!
Old Feb 22, 2012 | 09:19 AM
my 76 ray's Avatar
my 76 ray
If you LIKE dents in the crossmember then go ahead and use it. Otherwise, do as Aussiejohn suggests.
Old Feb 22, 2012 | 10:18 AM
81pilot's Avatar
81pilot
I have a piece of 2x10 that I place between my jack and the crossmember and jack it up, a piece of steel plate would work even better as the stress would not be on the dead center of the crossmember, no denting issues that way since it spreads the force out and then place my jack stands where I want them. But...my crossmember was already dented from some previous owner at some time, but I am not that **** about a dent in my crossmember, but don't want to make it worse.
Old Feb 22, 2012 | 10:37 AM
69 Chevy's Avatar
69 Chevy
I center my jack pad on the front lip of the front crossmember. Been doing it that way for 40 years.
Old Feb 22, 2012 | 11:38 AM
qwank's Avatar
qwank
I can't even fit a jack under the front bumper of my '81
Old Feb 22, 2012 | 09:07 PM
Tim81's Avatar
Tim81
I hear that.
Old Feb 22, 2012 | 10:31 PM
DeadStang's Avatar
DeadStang
at the sametime.
I use two jacks always and lift a little with each and go back and forth between them. I recently did the starter on my '70 and lifted the front on the frame rails, behind the front tires.
Old Feb 23, 2012 | 01:47 AM
Tim H's Avatar
Tim H
Like I said, if you dent that piece of metal then your car is folding in half anyways.
Old Feb 23, 2012 | 06:42 AM
Frankenvette's Avatar
Frankenvette
Old Feb 23, 2012 | 08:10 AM
MrJlr's Avatar
MrJlr
Old Feb 23, 2012 | 01:00 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I learned the hard way...................
Old Feb 23, 2012 | 01:50 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Owner's manual shows the factory jacking points. Do one side at a time. The two jack trick works if you have two jacks.
To Jacking up front end
