1978 Color Code......
Old Mar 3, 2012 | 12:33 PM
Jimmy W1's Avatar
Jimmy W1
Default 1978 Color Code......
I have a red 1978 Corvette and I am trying to find some touch up paint for it. The local Autozone said they can get some, but they need to know what the color code is. How do I find this out? Is the color code in the VIN number? Or is it stamped somewhere on the car? How can I found out what the color code is? Thanks for any help.
Old Mar 3, 2012 | 02:00 PM
oldsarge's Avatar
oldsarge
The color code for red in 78 was"72" if it is the original paint. That will not be enough for a painter or paint supplier. You need to know the formula for the paint. If you do a search here on the forum, I think the paint formula codes are listed.
You can also by tough up paint from most of the aftermarket suppliers.
Old Mar 3, 2012 | 02:19 PM
Jimmy W1's Avatar
Jimmy W1
OK. Thanks. But what if I just want to buy a can of touch up paint from a place like Autozone. They said I needed the color code so that they know what color I needed.
Old Mar 3, 2012 | 02:36 PM
CQRT's Avatar
CQRT
1978 Corvette Options
Code Color Quantity
10 Classic White 4,150
13 Silver 3,232
13U/07M Silver/Dark Gray (Anniversary) 15,283
19 Black 4,573
26 Light Blue 1,960
52 Bright Yellow 1,243
59 Light Beige 1,686
72 Red 2,074
82 Mahogany 2,121
83 Dark Red 2,084
89 Dark Brown 1,991
Isn't there a paint/trim plate riveted to your A-pillar base by the driver's door hinge?
Old Mar 3, 2012 | 02:45 PM
hunt4cleanair's Avatar
hunt4cleanair
If you really want it to match...I would break off a chuck of red or just take the t-top to an automotive paint shop. they can computer match it and mix you up a quart tho probably more pricey than autozone's one color fits three dozen automotive paint schemes.
Having said all that, I have a 1978 Chevrolet color chart and it reads 2973 for the color red along with the 72 code. Not sure if that helps.
Old Mar 3, 2012 | 03:40 PM
Jimmy W1's Avatar
Jimmy W1
Code Color Quantity
13 Silver 3,232
19 Black 4,573
26 Light Blue 1,960
72 Red 2,074
82 Mahogany 2,121
83 Dark Red 2,084
89 Dark Brown 1,991
I did notice that there was two shades of red that year. I didn't know to look there on the door. I looked on the door where the latch is. I'll check it out. Thanks
Old Mar 3, 2012 | 03:48 PM
Jimmy W1's Avatar
Jimmy W1
OK. I found it. It says 72L paint. I guess I never noticed that tag before. I've only had the car since 1991............ So, thanks everyone for the help. I appreciate it.
Old Mar 3, 2012 | 05:01 PM
7T1vette's Avatar
7T1vette
paintscratch.com
Just go on-line and order whatever you want: touchup bottle/brush, spray paint, etc. etc. If the paint on your car is 'original' or a repaint mixed to the original color, it should be a very good match.
Old Mar 3, 2012 | 08:01 PM
Jimmy W1's Avatar
Jimmy W1
Thanks guys for all of your help. I appreciate it very much!!
To 1978 Color Code......
